Switch weatherstation
tvitali
HI,
I have bought a new station Vantage 2 to replace my WS3600. I use WSWin by converting each days data so not in recording mode.
When I change station type from WS3600 to Vantage, everything are going out and I can ot see any data in my wswin32.
What does I need to do to switch station and keep datas ?
Thanks.
Thanks.
Hello,
you have to use first WS3600 and Export the data (File - exporting - export all month files)
Then you change to Vantage and import the data.(file - import weather data - and there hook at "all data"
Now you can see all.
An exakt explanation you can find on my site
at "Wie erreiche ich, dass" and then at "Stationswechsel"
Sorry, that it's only in German.
tvitali
HI,
I just notice something strange since I have done those operation of export/import I have a bug on all daily graphic.
In the max/min bar all min t° are to 0°C at 00h00, the same with the wind, ...
If I switch to la 24 hours mode same think with min temp to 0°C at start time of the graph.
If the real min temp is lower than 0°C, i have not this problem.
Any idea ?
Thanks.
Any idea ?
Thanks.
tvitali
My data seems correct.. The problem is the following...weneu hat geschrieben:Hello,
you can only export the monthfile and control it, if there is something going wrong with your data. Them import it again.
When i check the graph, you can see wrong minimum of 0.0°C à 00h00
If I check the table, I can't see this value
[/img]-
tvitali
