Unwanted sound
Dan
Unwanted sound
Beitrag von Dan »
Hello
Everytime when wswin makes a readout from my station (IROX) it plays a windowssound (ding.wav). Wswin is updating every minute so it plays the sound every minute. Is there a way to turn this off in Wswin?
Regards
Dan Svensson
Danksagung erhalten: 145 mal
@Dan,
that isn't normal.
There must be some reasons for that.
Look in the error-log-file (if activated).
But you can set a option the wswin.cfg file too:
(Wswin not started!!)
... for "InfoBeep=1" and change to "InfoBeep=0"
Dan
Beitrag von Dan »
This is what I found in wswinerr.txt
"2008-07-14 16:10:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 17:25:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 17:50:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 18:10:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 19:46:10.875 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 19:52:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 20:06:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 20:09:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 20:09:10.859 V2.93.19 1 50 0 no Data ... 3
2008-07-14 20:18:10.859 V2.93.19 1 50 0 Timeout ... 3
2008-07-14 23:36:10.875 V2.93.19 1 50 0 Timeout ... 3
2008-07-15 19:50:06.109 V2.93.19 1 50 0 Timeout ... 3
2008-07-17 08:22:02.718 V2.93.19 1 50 0 Error Data :0 19800000
2008-07-17 08:23:03.500 V2.93.19 1 50 0 CustomAlreadyOpen: custom.txt Line:0
2008-07-17 19:53:06.531 V2.93.19 1 50 0 Timeout ... 3
2008-07-17 20:43:06.531 V2.93.19 1 50 0 Timeout ... 3
2008-07-18 09:15:06.546 V2.93.19 1 50 0 Timeout ... 3"
Turned the beep off in wswin.cfg but it is still beeping.
I don´t know where to look in windows xp to find what is causing the beep, any suggestions?
Dan
@Dan,
this is a critical error (Timeout ... 3) - so you can't disable the beep.
Maybe your USB-Connection (cable) makes the problem.
