Hello,
After a clean re-install was hoping to get rid of the problem of not being able to exit the program. In vain as it seems.
Only solution: ctrl - alt - del and then finish the process.
Consequence: scaling and sensor settings made disappearing, on next start up have to set the sensors/scaling again.
Anyone have an idea what can be causing this ?
(Using version 2.96.6)
Note: I excluded WSwin in Avira from scanning, if that at all may be causing it.
Rgds,
Hans
Cannot exit the program (hanging) !
Jumanji
