Hi,
I have recently installed and configured wswin v2.96.10 against my ventus W831 weather station (same by wswin correctly as identical to model TE923 from other vendors).
I've set-up an account on wunderground. Station is "IDENMARK6".
What I'm seeing is that data is reported every hours, but not the latest data point! E.g. at 11:00 today, the data for 10:00 was added to the historical data.... At 12:00 it will add the data for 11:00.
The data reported for 10:00 matches the historic data for 10:00 when checking directly on wswin or the weather station itself.
So, the issue is that the most current data set is not reported.. This leads to two really annoying effects.
1) The data is delayed one hour
2) The "current data" on wunderground is never updated as it always gets "too old" data to update the current data set. For instance the temperate ture at 10:00 today was 18.6 C, but as the report was only made about 11:00, then the current value showing a very old value showing 20.3C. (the value at 11:00 is 18.8 C).
The internet/wunderground settings in wswin are set to transfer every hour, to use the internal browser, and to use at least 2 sec. between reports. The UTC time zone is correctly detected to -2 (summer time, Denmark).
Please help!
Regards,
Jens
[/img]
wswin - wunderground - data is reported with 1 hour delay...
Hello Jens,
I'm sorry, but i fear I can't help you. Your settings are correct but the behaviour is not normal. When I look at my account, there are actual (time is at the moment 12:40) values of 12:00 and at yours only from 11:00
What can you see in WSWIN, when you have a look at "Internet - adjustments - wunderground.com" and there at "Last report"
Here I can find actually
10:00 09.07.2012 UTC
and that fits
and that fits
