Switch weatherstation
Verfasst: 13 Dez 2007 13:34
von tvitali
HI,
I have bought a new station Vantage 2 to replace my WS3600. I use WSWin by converting each days data so not in recording mode.
When I change station type from WS3600 to Vantage, everything are going out and I can ot see any data in my wswin32.
What does I need to do to switch station and keep datas ?
Thanks.
Verfasst: 13 Dez 2007 14:04
Hello,
you have to use first WS3600 and Export the data (File - exporting - export all month files)
Then you change to Vantage and import the data.(file - import weather data - and there hook at "all data"
Now you can see all.
An exakt explanation you can find on my site
at "Wie erreiche ich, dass" and then at "Stationswechsel"
Sorry, that it's only in German.
Verfasst: 13 Dez 2007 14:34
von tvitali
Thank you very much.
I have understand.
I will do the test.
Verfasst: 14 Dez 2007 21:05
von tvitali
I have done it
Thanks.
Verfasst: 16 Apr 2008 18:35
von tvitali
HI,
I just notice something strange since I have done those operation of export/import I have a bug on all daily graphic.
In the max/min bar all min t° are to 0°C at 00h00, the same with the wind, ...
If I switch to la 24 hours mode same think with min temp to 0°C at start time of the graph.
If the real min temp is lower than 0°C, i have not this problem.
Any idea ?
Thanks.
Verfasst: 06 Mai 2008 10:51
von tvitali
Nobody have an idea ??
Verfasst: 06 Mai 2008 11:13
Hello,
you can only export the monthfile and control it, if there is something going wrong with your data. Them import it again.
Verfasst: 06 Mai 2008 12:27
von tvitali
weneu hat geschrieben:Hello,
My data seems correct.. The problem is the following...
When i check the graph, you can see wrong minimum of 0.0°C à 00h00
If I check the table, I can't see this value
[/img]
Verfasst: 06 Mai 2008 13:01
Hello,
yes, I can see and understand your problem, but I have no idea.
Wait, until Werner (the programm author) sees it, I think he can help.
Verfasst: 06 Mai 2008 13:03
@tvitali,
why you don't use the current version V2.93.19 (not V2.93.7 = very old)
Verfasst: 06 Mai 2008 13:11
von tvitali
Werner hat geschrieben:@tvitali,
I will test with the new version...
I have not install the new versions because I was happy with this one.
I will let you know the result.
Thanks.
Verfasst: 06 Mai 2008 13:23
von tvitali
It works with the new version.
Thanks a lot.
