Turn off computer
Verfasst: 12 Jan 2008 18:59
von aco47
I can not turn off my computer, if I do not quit WsWin first. All other programs stop and quit automaticaly. Can this be changed?
Verfasst: 12 Jan 2008 21:34
did you read in the info_r.txt and here
Known Problems: since V2.80.2
Verfasst: 14 Jan 2008 17:47
von aco47
Hello Werner,
Sorry, but in info_r_en.txt I do not find any connection with my problem.
Drago
Verfasst: 14 Jan 2008 18:17
Hello,
since V2.80.2
with introduction of a posted component version, WsWin32 does not react again anymore to the
Windows-embassy "program termination/closing" !!!
That is, the program WsWin32 must before Windows new start/-termination are self ended.
That means, you have to end WSWIN yourself befor turning off your PC.
Another way for terminating automatically is, to use the windows-program "shutdown.exe"
Or, the next way: you end WSWIN by itself: "file - options - time controling"
Verfasst: 25 Aug 2010 21:57
von Blaz88
I have question about a reboot of a computer, my automatic turn off works excellently (file-options-time controling), I am interested in is wanted that somewhere in wswin to set, that a computer starts automatically after in the morning again, I beg if me advise some supposed save this matter, that computer in the morning automatically started up.
Thanks, Blaž
Verfasst: 25 Aug 2010 22:23
Hello,
you cannot start the computer by WSWIN.
You have to do this by the BIOS of your system.
Verfasst: 27 Aug 2010 21:06
von Blaz88
Some have other this arranged, are you turning off computers in the evening or have turned on 24 hours daily? Or it will be possible maybe sometimes, that a computer starts automatically on certain hour, in which from next updates maybe. If not, be asked somewhere set, that data updated from eighth of hour in the morning to ten of hour in the evening.
Thanks, Blaž.
Verfasst: 04 Sep 2010 13:50
von Blaz88
Blaz88 hat geschrieben:Some have other this arranged, are you turning off computers in the evening or have turned on 24 hours daily? Or it will be possible maybe sometimes, that a computer starts automatically on certain hour, in which from next updates maybe. If not, be asked somewhere set, that data updated from eighth of hour in the morning to ten of hour in the evening.
Thanks, Blaž.
