UV-I maxvalue on IROX
Verfasst: 10 Mär 2008 21:36
von Dan
Hello
In current.html the UV shows a maxvalue of 0.4 UV-I but when I put %maxval[41]% in the wap.txt it shows a maxvalue of 0.2 UV-I. Am I doing something wrong??
Dan
Verfasst: 11 Mär 2008 07:56
@Dan,
are the files at the same time created?
Do you use the UV adapting to the VantagePro values?
Verfasst: 11 Mär 2008 19:41
von Dan
The files are created at the same time and yes I have the UV adapting to the VantagePro.
If you want to see what it looks like...
http://schnyggve.110mb.com/weather/custom.html
http://schnyggve.110mb.com/weather/current.html
Dan
Verfasst: 12 Mär 2008 07:31
@Dan,
can I have a look at the source, where the variable is used?
Verfasst: 12 Mär 2008 18:23
von Dan
This is from the wap.txt that i use.
%customfile=c:\program\wswin\text\test.txt%
%curval[35]%%unit_on%
%curval[35]%%unit_off%
%windmaxms% m/s %maxtimecurday[35]%
%curval[45]% %unit_on%
%curval[45]% %unit_off%
%windgmaxms% m/s %maxtimecurday[45]%
%curval[36]%%unit_off%
%domwind_txt%
%curval[0]%%unit_on%
Min %minval[0]%%unit_on% %mintimecurday[0]%
Max %maxval[0]% %maxtimecurday[0]%
%curval[33]%%unit_off%
%ws_barotendencytxt%
%curval[18]% %unit_on%
%curval[41]% %unit_on%
%maxval[41]% %maxtimecurday[41]%
%rainday%%unit_off%
%curval[0]%
%curval[18]%
%curval[44]%%unit_on%
Min %minval[33]%%unit_on% %mintimecurday[33]%
Max %maxval[33]% %maxtimecurday[33]%
Dan
Verfasst: 12 Mär 2008 23:07
@Dan
at the moment both are equal.
... but is your shown source really the used at your web site for the instruments?
Verfasst: 13 Mär 2008 08:02
von Dan
This is the source for the instruments then I use Samurize to do the instruments from test.txt.
I have removed the UV vantage parameter and since then the reading shows the same (for one day). We dont have much sun at the moment so i´ll wait and see how it looks when the weather changes.
Dan
Verfasst: 16 Mär 2008 11:04
von Dan
Now the sun has arrived so now I have compared the "UV -> VantagePro 0..16 UV" parameter and when I use the parameter the readings are different, if I remove the parameter the readings are the same. Does it matter what this parameter is set to for accuracy in the readings?
Dan
Verfasst: 16 Mär 2008 14:02
@Dan,
there are (or was) two different hardware of the UV-Sensor:
- bright diffusor
- dark diffusor
The adaption "UV -> VantagePro 0..16 UV" is necessary for the
bright one.
Whereas the sensor with the dark diffusor show to low values (=my experience)
Verfasst: 16 Mär 2008 15:14
von Dan
I think I have the dark diffusor, is there some way to check how accurat it is?
Shall I have the "UV -> VantagePro 0..16 UV" set or not?
Dan
Verfasst: 16 Mär 2008 16:25
@Dan,
no.
I need with the dark one a correction factor of ~1.8 too.
Verfasst: 01 Apr 2008 14:59
von Dan
When I set a correction factor of 1.8 it shows right in my instruments in custom.html but not in the current.html. What have I missed?
Dan
Verfasst: 01 Apr 2008 21:30
@Dan,
it seems that the
UV X (original value) and
UV (corrected/adapted value) is shown?
I don't know.
Verfasst: 02 Apr 2008 20:09
von Dan
It shows the corrected value in the textfile that I create with wap.txt and uncorrected value in current.html and aktuell.htm. It´s also uncorrected in the min/max bar.
Dan
Verfasst: 11 Apr 2008 14:49
von Dan
Dan hat geschrieben:It shows the corrected value in the textfile that I create with wap.txt and uncorrected value in current.html and aktuell.htm. It´s also uncorrected in the min/max bar.
Dan
I can´t get this to work. Why isn´t the corrected UV value shown in current.html and aktuell.htm when the it´s shown in my wap.txt??
Dan
