Longest Frost Problem
fcorey
Beitrag von fcorey »
Hello,
I have a problem with the longest frost duration. The longtime dryness duration works correctly and WsWin is correctly calculating the first and last frost of the year but longest frost duration is not working (it shows 01/01/1980).
I have followed this procedure:
selected outside temperature sensor as frost sensor
all wrong values with zeros completely overwrite
Windows with OK ONE close (importantly!!)
WSWIN terminate and start again
the individual months “page through”
and I have updated the Internet files using "dryness/frost duration and year file" but the longest frost duration is still not working (both in the .gif table and in custom.html).
One possibility is that it could be in the middle of the longest frost to date (it has been below 32F since January 13th).
Do you have any ideas on how to correct the longest frost duration problem?
Thank you,
Fred Corey.
Danksagung erhalten: 145 mal
@Fred,
what is your longest frost duration (or should be) ?
What "Recording begin ..." to you have?
fcorey
Werner,
Thank you for the quick reply. I have set recording to begin 08/30/2005 which is when my data begins. See:
Thank you,
Fred Corey.
@Fred,
I have no idea.
Only: you can once again update the statistic dates
under Internet, Update graphics/tables... and the option "Dryness/Ice Days Time"
fcorey
Werner,
I have tried everything but the longest frost duration always reverts to 01/01/1980. I will reinstall WsWin and see if that corrects the problem.
Thank you,
Fred Corey.
arralifte
Beitrag von arralifte »
Habe das gleiche Problem bei V2.93.17 / WS2000PC V2.4. Gibt es hierzu mittlerweile eine Lösung?
Welcher Sensor wird für die Frostauswertung herangezogen?
mfg
Rainer
Hallo Rainer,
"Wetterstation - Spezialsensoren" --> der Sensor, den Du als "Sensor Frost" eingestellt hast.
Lösung Dauerfrostproblem:
- "Wetter - Wettervorhersage - Statistikdaten" --> Resetbutton bei "letzter Regen" und "letzer Frost" drücken
- "Wetter - Statistikdaten - Langzeitwerte" und hier alle Werte bei "Dauer Trockenheit" und "Dauer Frost" mit Nullen überschreiben --> Fenster mit "Ok+Schließen" schließen (wichtig!)
- "Internet - Grafiken/Tabellen aktualisieren" und hier Haken setzen bei "Trockenheit Eistage Zeit" sowie "Jahr Datei" und den gesamten Zeitraum, den man wünscht, als Aktualisierungszeitraum wählen
Danach sollten die Werte stimmen.
arralifte
Hallo Werner
Vielen Dank für die Hilfe.
Habe die Vorgehensweise wie beschrieben durchgeführt. Der letzte Frost und Frostdauer wird jetzt wie gewünscht angezeigt.
Rainer
