Problem with images
Andrea75
Problem with images
Beitrag von Andrea75 »
Hi! How can I solve this problem with graphic images?
In my pc I use a resolution of 1280x1024, and I set 800x600 for graphics, but how you can see I can't see images correctly.
I try to use +30 pixel function, but it can't help me. Some suggestions?
This is my settings:
Zuletzt geändert von Andrea75 am 24 Mär 2008 19:34, insgesamt 1-mal geändert.
Hello,
your Pixel-correction is not ok. The graphioc ist too high, it should look like this:
Set your pixel-correction to "0", then control and when it doesn't fit, correct it a little.
Andrea75
I have tried, but the images are correct only if I set the same dimension of my screen resolution. If I try to decrease it all graphics are not shown correctly. I have tried a lot of combination of setting, but nothing change.
Any suggestion?
Hello,
I think you have forgotten to set the hook at the pixel-correction field.
That's all I can say.
