I apologize a great deal as I probably could get it from the forum but I do not speak Geram at all.
I have TFA Nexus (with additional 3 Temp/Hydro sensors). t workes for me fne for 6 months already and I like it. I dowloaded WsWin32 (recent ver 2.93.13) and I failed to make it running my Nexus. I assume I need to be in file-watching mode? I selected weather station Moebius/Irox/Nexus, right? Then I should select 'without interface', right? Which file to select for watching?
Could you, pls help.
Regards, Pawel Piwowar
PS: TFA recommended me your software to use to create web sites so I consider to buy it but got stacked at the beginng.
How to make WsWin32 connected with TFA Nexus
Hello,
first you have to load the file usb.dll from the user-site and store it in the programm path (normally c:\programme\wswin)
Then you select as weather station Mebus/Irox/Nexus. After that WSWIN should find your station .You can see it in the status bar, shown like "...station found".
No, that's not right. WSWIN can read the data directly from the station, there is no file-watching necessary.I assume I need to be in file-watching mode?
Piwowar
