How to make WsWin32 connected with TFA Nexus
Piwowar
Beitrag von Piwowar »
I apologize a great deal as I probably could get it from the forum but I do not speak Geram at all.
I have TFA Nexus (with additional 3 Temp/Hydro sensors). t workes for me fne for 6 months already and I like it. I dowloaded WsWin32 (recent ver 2.93.13) and I failed to make it running my Nexus. I assume I need to be in file-watching mode? I selected weather station Moebius/Irox/Nexus, right? Then I should select 'without interface', right? Which file to select for watching?
Could you, pls help.
Regards, Pawel Piwowar
PS: TFA recommended me your software to use to create web sites so I consider to buy it but got stacked at the beginng.
Hello,
first you have to load the file usb.dll from the user-site and store it in the programm path (normally c:\programme\wswin)
No, that's not right. WSWIN can read the data directly from the station, there is no file-watching necessary.
Then you select as weather station Mebus/Irox/Nexus. After that WSWIN should find your station .You can see it in the status bar, shown like "...station found".
Piwowar
Great! Thanks for the prompt response. It works now!
A question:
I am not sure it has any practical meaning - what if I try to run Nexus software in parallel to WsWin ? Just to keep data in both.
Regards, Pawel
