Lost Connection and Restoration of Data (IROX PRO)
Johan S
Beitrag von Johan S »
I have an IROX-PRO which I am currently bringing into operation. I have at a few ocassions lost connection to the computer/WeatherStation for a period of time. Consequently the graphs are not updated for the period the connection fails. The IROX-PRO console has a memory that stores the last 3200 data points so it is thus possible to recover these data to WeatherStation.
What is the best way to do the "restoration" of the graphs. I have so far used a quite complicated way which means that I have closed the program, deleted data found in ws-newdata.csv from the point where the connection is lost. Then I have deleted the WD_03_08.DAT file. After these changes the program has been restarted and voila' the graphs are complete. But is there a simpler way ?
Danksagung erhalten: 145 mal
@Johan,
never delete a Wswin month-data-file - better rename it.
If you delete the month-data-file (here wd_03_08.dat for Feb 2008) the software tries to get the data again.
