IROX lost connection with one tempsensor
Dan
Beitrag von Dan »
I have 2 tempsensors connected and they are combined to read the lowest temp. If one of the sensors loose connection with the IROX Wswin still remember the value from the lost sensor and Wswin shows wrong temp. Is there a way to make Wswin not to remember the value from the lost sensor and start to read from the one that still have connection?
Dan
Hello Dan,
no, there is no way. When you combine a sensor, WSWIN will do this. And when there is no value of the second sensor, WSWIN uses the last value which was transmitted.
