evapotranspiration
tvg
evapotranspiration
Beitrag von tvg »
Hallo Werner(s)
Is it possible to make a calculation from the ET during a certain period like the seasoncalculations?
Groet
Theo
Danksagung erhalten: 145 mal
Hello,
should work with the season-vars
Helo,
for example:
You take
%season_avg[id~ddmmyyyy~ddmmyyyy]%
and as "id" you set "40"
tvg
Beitrag von tvg »
Hello again
Thank you for your quick answers.
I tried
%season_avg[40~14052009~20052009]%
and the result is 0,000, I tried also with season_sum and the result was also 0,000
Groet
Theo
Hello Theo,
it works definitely. Perhaps you have missed to activate the calculation in WSWIN
"weather - statistic dates - parameters" and there set a hook at "Calculate Evapotranspiratiuon"
tvg
Beitrag von tvg »
The hook was set, but under Wetter, Wettervorhersage, Statistics in the program, isn't it possible to select id 40. It jumps from 39 to 43.
Groet
Theo
Hello Theo,
in this moment I see, that you have got a WMR928 and as I think, there it isn#t possiible to use this feature.
Lokk in the helpfile:
WMR918 bei diesen Systemen sind 6..16, 23..32, 38..42 nicht relevant
tvg
Beitrag von tvg »
That's a pitty, thank you anyway in helping me.
Groet
Theo
