Rainfall
Meteonoord
Hi Werner,
It didn't work. the results are still the same.
At http://www.meteonoord.com/node/5 you see my yearly rainfall at the moment from 253,6 mm.
My Davis Vantage says 324,6 mm. I can also see it in WsWin and that is correct. In WsWin goto Weather station then to Adjustments and at last to Baro/Rain/ET. Herer I see also year rainfall 324,6.
How is it possible that current shows 253,6 ?
I hope i'm clearly now.
Regards,
Bert
Regards,
Bert
Meteonoord
Hello Bert,
when there are no values, you can do nothing.
The only way is, to fill in an imaginative value for january and february, so that the total value ist correct.
To do this, you have to export january and february and then fill in rain-values and afterwards you can import again.
Of course this is an unusual way, but when you have no real values, you can only do this.
Meteonoord
Hello Bert,
Of course you can import weatherdisplay-data for example.Go to
"file - import weather data" and there choose "weather-display log-file"
The better way perhaps would be, to konvert the weatherlink-data
"file - converting weather data" and ther choose the weatherlink-file (2009-01.wlk)
Yes, there is. You didn't tell me before, that you have got also other data.But is there also a other way ?
Meteonoord
