Turn off computer
aco47
Turn off computer
Beitrag von aco47 »
I can not turn off my computer, if I do not quit WsWin first. All other programs stop and quit automaticaly. Can this be changed?
Danksagung erhalten: 145 mal
did you read in the info_r.txt and here
Known Problems: since V2.80.2
aco47
Beitrag von aco47 »
Hello Werner,
Sorry, but in info_r_en.txt I do not find any connection with my problem.
Drago
Hello,
since V2.80.2
with introduction of a posted component version, WsWin32 does not react again anymore to the
Windows-embassy "program termination/closing" !!!
That is, the program WsWin32 must before Windows new start/-termination are self ended.
That means, you have to end WSWIN yourself befor turning off your PC.
Another way for terminating automatically is, to use the windows-program "shutdown.exe"
Or, the next way: you end WSWIN by itself: "file - options - time controling"
Hat sich bedankt: 75 mal
Beitrag von Blaz88 »
I have question about a reboot of a computer, my automatic turn off works excellently (file-options-time controling), I am interested in is wanted that somewhere in wswin to set, that a computer starts automatically after in the morning again, I beg if me advise some supposed save this matter, that computer in the morning automatically started up.
Thanks, Blaž
Hello,
you cannot start the computer by WSWIN.
You have to do this by the BIOS of your system.
Some have other this arranged, are you turning off computers in the evening or have turned on 24 hours daily? Or it will be possible maybe sometimes, that a computer starts automatically on certain hour, in which from next updates maybe. If not, be asked somewhere set, that data updated from eighth of hour in the morning to ten of hour in the evening.
Thanks, Blaž.
Blaz88 hat geschrieben:Some have other this arranged, are you turning off computers in the evening or have turned on 24 hours daily? Or it will be possible maybe sometimes, that a computer starts automatically on certain hour, in which from next updates maybe. If not, be asked somewhere set, that data updated from eighth of hour in the morning to ten of hour in the evening.
Thanks, Blaž.
