WSWIN files
whozee
WSWIN files
Beitrag von whozee »
In my map c:/wswin, I see a lot of files like this:
-vantagepro_20150401.txt
-wswinerr_20150401.txt
Inside this files you can read values of measured sensors.
In wswinerr.......TXt you can see things that went wrong. Why they went wrong, I do not understand.
I also have some wswin_201150225.trc files. I can not open these files.
But my mean question is: Can I delete all this files??
Hello,
these are "errorfiles", if you don't need them (because of problems) you can delet them.
You can also open in WSWIN "File - Options" and remove the hook at "debug"
Then they will be no longer created.
Especially these file you should not create, when not necessary, because it gets bigger and bigger.
Remove the hook at "Log Error (communication , data correction)"
whozee
Hello Werner,
Txs for your quick and well understood explanation.
Gruss,
Wim Hozee
