In my map c:/wswin, I see a lot of files like this:
-vantagepro_20150401.txt
-wswinerr_20150401.txt
Inside this files you can read values of measured sensors.
In wswinerr.......TXt you can see things that went wrong. Why they went wrong, I do not understand.
I also have some wswin_201150225.trc files. I can not open these files.
But my mean question is: Can I delete all this files??
WSWIN files
whozee
Hello,
these are "errorfiles", if you don't need them (because of problems) you can delet them.
You can also open in WSWIN "File - Options" and remove the hook at "debug"
Then they will be no longer created.
Remove the hook at "Log Error (communication , data correction)"
Especially these file you should not create, when not necessary, because it gets bigger and bigger.I also have some wswin_201150225.trc files.
whozee
