wswin_nrt und WS2300
Alfi
Beitrag von Alfi »
Hallo,habe ein Problem.
Ich benutze folgende wswin_nrt:
%customfile=c:\wdl\clientraw.txt%
%openfile&remove=ws_clientrawdaily.txt%
%unit_off%%alwaysseppoint_on%12345 %windkts% %windgkts% %nrtval[36]% %nrtval[0]% %nrtval[-1]% %nrtval[33]% %rainday% %rainmonth% %rainyear% 0 0 %nrtval[1]% %nrtval[17]% %ws_comparestr=- -~%nrtval[13]%~0% %forecast_number_vant% %nrtval[2]% %nrtval[18]% 1 %avgvalpast[34~-1~00~0000]% %ws_comparestr=- -~%nrtval[3]%~0% %ws_comparestr=- -~%nrtval[4]%~0% %ws_comparestr=- -~%nrtval[5]%~0% %ws_comparestr=- -~%nrtval[6]%~0% %ws_comparestr=- -~%nrtval[7]%~0% %ws_comparestr=- -~%nrtval[8]%~0% %ws_comparestr=- -~%nrtval[19]%~0% %ws_comparestr=- -~%nrtval[20]%~0% %ws_comparestr=- -~%nrtval[21]%~0% %ws_hour% %ws_minute% %ws_nrt_sec% %ws_modtext[Oberhausen Live]%-%ws_nrttime% 0 %ws_day% %ws_month% %ws_year% 0 0 0 0 0 0 0 %nrtval[44]% 0 %maxval[0]% %minval[2]% 0 %ws_modtext[Vorhersage:%forecast_txt%]% %ws_comparestr=0~%ws_baro1h%~0 %%ws_arraywind[20]% %windgmaxkts% %nrtval[43]% %ws_calc[/]=%cloudline%~0.3048~1% %ws_day2%/%ws_month%/%ws_year% 0 0 %nrtval[44]% %minval[44]% %ws_comparestr=- -~%nrtval[41]%~0% %ws_arraywind[10]% %ws_arraytemp[10]% %ws_arrayrain[10]% 0 0 %heatindex[2]% %windmaxkts% 0 --- --- %avg10minwinddir% 0 0 0.0 0.0 %ws_comparestr=- -~%nrtval[20]%~0% %ws_comparestr=- -~%nrtval[21]%~0% %ws_comparestr=- -~%nrtval[22]%~0% %ws_comparestr=- -~%nrtval[23]%~0% %ws_comparestr=- -~%nrtval[24]%~0% %ws_comparestr=- -~%nrtval[42]%~0% %maxval[1]% %minval[1]% %wetbulbtemp% %maxval[33]% %minval[33]%
%alwaysseppoint_off% %ws_delline%
Daraus wird folgende clientraw erzeugt:
12345 0.0 0.0 225 21.0 37 1016.3 0.0 25.4 3458.4 0 0 22.5 42 0 -1 21.0 37 1 0.0 0 0 0 0 0 0 0 0 0 15 32 00 Oberhausen_Live-15:33 0 12 10 2005 0 0 0 0 0 0 0 21.0 0 21.1 13.1 0 Vorhersage:bewoelkt -1.00.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 3.1 2.5 0.0 0.0 0.0 0.0 0.0 2.9 0.0 0.0 0.0 4.9 5.8 7696.9 12/10/2005 0 0 21.0 13.1 0 2.5 0.0 0.0 0.0 0.0 0.0 2.9 0.0 0.0 0.0 21.1 21.0 21.0 21.0 21.0 21.0 21.0 21.1 21.0 21.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 21.0 4.9 0 --- --- 158 0 0 0.0 0.0 0 0 0 0 0 0 22.9 20.7 12.9 1017.8 1015.8
Die wswin_nrt ist wohl für eine Vantage.
Mit meinen bescheidenen Mitteln läuft es jetzt mit der WS2300.
Habe nur noch Probleme mit dem Datum und dem Wetter-Icon.
Es muss doch einen Spezialisten geben,der mir da helfen kann ???
http://home.arcor.de/alfommert/oberhausenlive
Zuletzt geändert von Alfi am 12 Okt 2005 15:20, insgesamt 1-mal geändert.
rolsch
Beitrag von rolsch »
Wenn du WDL nutzt:
In den Templates aus dem User-Verzeichniss ist wahrscheinlich ein Fehler:
Template: ws_clientraw.txt
falsch:
richtig:
%ws_comparestr=0~%ws_baro1h%~0% %ws_arraywind[20]%
Man beachte den kleinen Unterschied...
Ansonsten kannst du ja mal diese Templates testen,
sie sind aber noch nicht perfekt!
http://namoro.de/test/wdl_templates_ws2000.zip
Achtung:
In den Templates unbedingt die ersten beiden Zeilen entsprechend
anpassen und auch in der clientraw.txt den Stationstext anpassen...
-> Ergebniss dieser Templates: http://namoro.de/wetter/wetter/wdl/
Falls jemand hier mit einem WS2000-System Verbesserungen kennt,
bitte kurze Info man mich - danke!
Zuletzt geändert von rolsch am 21 Mai 2006 13:13, insgesamt 3-mal geändert.
Alfi
Antwort für Rolsch
Beitrag von Alfi »
Beir Dir läuft WDLive ja wohl perfekt.
Mit Deinen Templates läuft es bei mir nicht.
Diese Clientraw.txt hatte ich als Grundgerüst.
Nach tagelangen Experimenten(nur 30% Ahnung) lief es dann so wie unten zu sehen.
Bis auf 2 oder 3 Fehler gehts schon...
Meine Hoffnung ist ja,daß einer von den "richtigen Experten" für mich eine Lösung weiß.
Bei Dir möchte ich mich für Deine Bemühungen bedanken !!!!
[/url]http://home.arcor.de/alfommert/oberhausenlive
rolsch
Hmm,
von perfekt ist meine WDL noch weit entfernt,
da dies nur ein nonpublic Testbetrieb in der Grundkonfiguration ist:
http://namoro.de/wetter/wetter/wdl/index.html
http://namoro.de/wetter/wetter/wdl/index1.html
http://namoro.de/wetter/wetter/wdl/index2.html
http://namoro.de/wetter/wetter/wdl/index3.html
http://namoro.de/wetter/wetter/wdl/index4.html
http://namoro.de/wetter/wetter/wdl/index5.html
http://namoro.de/wetter/wetter/wdl/index6.html
http://namoro.de/wetter/wetter/wdl/index7.html
http://namoro.de/wetter/wetter/wdl/index8.html
http://namoro.de/wetter/wetter/wdl/index9.html
-> dies sind verschiedene Einstellungen in der Datei "wdlconfig.xml"
In deiner clientraw.txt hast du noch Geislautern drinne stehen :-)
Werden bei dir auch diese Dateien erzeugt:
clientrawdescription.txt
clientrawextra.txt
clientrawdaily.txt
Wenn ja,
bitte mal hier posten,
evtl. den Link zu diesen Dateien im Web.
In deiner clientraw.txt fehlen Messdaten (an den - Einträgen zu sehen).
Hast du auch die 24 Stunden-Ansicht aktiviert?
Alfi
Antwort für Rolsch
Beitrag von Alfi »
Mit den xml kenne ich mich halbwegs aus.
Ich benutze obige clientraw und wswin_nrt.
Ob die anderen zwei Dateien erzeugt werden,weiß ich gar nicht.
Aber die braucht man doch nicht unbedingt. Oder??
24 Std. Ansicht ist da.
Danke !!
rolsch
Alfi
Bitte an Rolsch
Beitrag von Alfi »
Würdest Du mir freundlicherweise zu Deinem 1.Template die wswin_nrt zur Verfügung stellen ?????
Wenn ja bedanke ich mich schon mal im vorraus....
rolsch
Hmm,
bin ja auch noch in der Experimentalphase,
aber ist da etwas an mir vorbei gegangen?
Ich erstelle keine wswin_nrt, sondern nur die 3 Dateien,
welche mit den weiter oben genannten Templates erstellt werden.
Diese werden 'nur' alle 4 Minuten aktualisiert,
da mit der WS2xxx ja eh keine solch kleinen Ausleseintervalle
für 'Live'-Betrieb möglich sind bezüglich Wind & -Richtung
Die Optik wo was positioniert und sichtbar ist wird ja in der Datei "wdlconfig.xml" festgelegt.
Alfi
Antwort an Rolsch
Beitrag von Alfi »
Pardon,daß war jetzt ein Denkfehler von mir.(Bin nicht mehr der jünste)
Mit Deinen Templates habe ich die Sache halbwegs am laufen.(Nach kleinen Änderungen).
Mein Problem ist,daß beim Wechsel der Datumsanzeige nur die Uhrzeit richtig angezeigt wird,beim Datum ist dann ein Fehler.
rolsch
Hi,
nun in deiner clientraw.txt ist noch 1 Leerzeichen zwischen der 0 und der 14 zuviel:
...Oberhausen_Live-19:55 0 14 10 2005 0...
Alfi
Hallo Rolsch
Beitrag von Alfi »
Erst mal Dank für Deinen Einsatz...
Und jetzt noch mal Pardon...War eine alte clientraw.Hab sie ersetzt....
Alfi
WDLive für WS2300
Beitrag von Alfi »
Nach langen Experimenten ist es mir endlich gelungen eine gut funktionierende wswin_nrt für die WS 2300 zu basteln.
Eure Meinung würde mich interessieren.(Evtl. Verbesserungsvorschläge?)
Viele Grüße
robbie
Beitrag von robbie »
Hallo Alfi
Da hast du dir eine ganze menge Arbeit gemacht.
Sehr informativ und dank der grossen Schrift auch sehr gut zu überblicken.
Deshalb fällt auch gleich auf das im Mai Oberhausen ziemlich nah an der Sonne vorbeiflog ;-) Die max.Temp von 46,3 Grad war sicher nicht im Schatten.
Robert
Holli
Re: WDLive für WS2300
Beitrag von Holli »
Alfi hat geschrieben:Nach langen Experimenten ist es mir endlich gelungen eine gut funktionierende wswin_nrt für die WS 2300 zu basteln.
Was kann man an einer leeren grünen Fläche noch verbessern? Hast du dir die Seite mal mit Opera angesehen?
Mit Firefox sehe ich was, aber mein Prozessor läuft dabei am Anschlag. Ich bin schnell wieder weg.
Sorry, ich finde Seiten und Grafiken, wie sie WsWin erzeugt, einfach angenehmer und übersichtlicher.
Alfi
Grosse grüne Fläche..
Beitrag von Alfi »
Mein Gedanke war,daß ich schön auf dem Sofa sitze und trotzdem alles verfolgen kann.
Robbie,Du hast Recht.Mittags liegt der Fühler kurz in der Sonne...
Zu Hollie muss ich sagen,wenn Du nur eine grüne Fläche siehst und Dein Prozessor schlapp macht hast Du wohl ein Problem...
Natürlich kann es sein,daß die von WsWin erzeugten Seiten übersichtlicher sind.....Aber die sieht man überall...
Ausserdem meinte ich untenstehenden Link.(WDLive erzeugt mit WsWin)
Danke für eure Beiträge..
