UV-I maxvalue on IROX
Dan
Hello
In current.html the UV shows a maxvalue of 0.4 UV-I but when I put %maxval[41]% in the wap.txt it shows a maxvalue of 0.2 UV-I. Am I doing something wrong??
Dan
Dan
Dan
The files are created at the same time and yes I have the UV adapting to the VantagePro.
If you want to see what it looks like...
http://schnyggve.110mb.com/weather/custom.html
http://schnyggve.110mb.com/weather/current.html
Dan
Dan
Dan
This is from the wap.txt that i use.
%customfile=c:\program\wswin\text\test.txt%
%curval[35]%%unit_on%
%curval[35]%%unit_off%
%windmaxms% m/s %maxtimecurday[35]%
%curval[45]% %unit_on%
%curval[45]% %unit_off%
%windgmaxms% m/s %maxtimecurday[45]%
%curval[36]%%unit_off%
%domwind_txt%
%curval[0]%%unit_on%
Min %minval[0]%%unit_on% %mintimecurday[0]%
Max %maxval[0]% %maxtimecurday[0]%
%curval[33]%%unit_off%
%ws_barotendencytxt%
%curval[18]% %unit_on%
%curval[41]% %unit_on%
%maxval[41]% %maxtimecurday[41]%
%rainday%%unit_off%
%curval[0]%
%curval[18]%
%curval[44]%%unit_on%
Min %minval[33]%%unit_on% %mintimecurday[33]%
Max %maxval[33]% %maxtimecurday[33]%
Dan
%domwind_txt%
%rainday%%unit_off%
%curval[0]%
%curval[18]%
Dan
Dan
Dan
Dan
Dan
Dan
Dan
I can´t get this to work. Why isn´t the corrected UV value shown in current.html and aktuell.htm when the it´s shown in my wap.txt??Dan hat geschrieben:It shows the corrected value in the textfile that I create with wap.txt and uncorrected value in current.html and aktuell.htm. It´s also uncorrected in the min/max bar.
Dan
Dan
