Problem mit WsWin oder VP2 Datalogger??
Oliver47
ich habe diesbezüglich im Wetterstationsforum schon einen Beitrag geschrieben!
Leider habe ich aber bis jetzt keine richtige Auskunft bekommen!
Folgendes Problem tritt bei mir auf!
Ich kann keine Daten u.a. an Wetterspiegel, Wetterpool senden, bzw. die datei kann von den jeweiligen Foren nicht eingelesen werden!
Laut meines Ordner WsWin html und Text, werden aber die Dateien richtig abgearbeitet!!
Will man nun die Datei lesen, sprich die jeweiligen Betrieber, erhalten dieser folgendes:
IMPORTANT! READ CAREFULLY BEFORE USING THE SOFTWARE By using this Software you indicate acceptance of the following Software License Agreement.
SOFTWARE LICENSE AGREEMENT
This Software License Agreement ("Agreement") is a legal agreement between you (either an individual or an entity) and Davis Instruments Corporation ("Davis"). If you do not agree to the terms of this agreement, return the Software packet and the accompanying items within 14 days to the place you obtained them for a full refund.
GRANT OF LICENSE
This license agreement permits you to use one copy of the Davis Instruments Software included in this package in object code form only (the "Software") on a single computer, subject to the terms and conditions of this Agreement. The Software is in use on a computer when it is loaded into temporary memory (i.e., RAM) or installed into permanent memory (e.g., a hard disk) of that computer. The Software may assist in the . of data ("Data") and in creating content that may be displayed on www.DavisNet.com or another website ("Content").
LICENSE RESTRICTIONS
1. You may not install the Software on a network, unless the Software is used on only one computer or a separate license ("Extra User License") is obtained for each additional computer on which the Software is used. However, you may install the Software on a network for the sole purpose of distribution to additional computers, provided you have an Extra User License for each additional computer. Contact Davis for clarification or information about Extra User Licenses. You may make no more than a reasonable number of copies of the Software for your own use, subject to all of the terms and conditions of this Agreement, including, without limitation, this Section.
2. You may not, and may not permit any third party to, make changes, decompile, reverse engineer or seek to discover the source code of the Software.
3. You may not sublicense, rent, lease, or loan the Software, but you may transfer the Software, accompanying Davis hardware, and Documentation on a permanent basis provided you retain no copies of any of the Software or Documentation and the recipient agrees to the terms of this Agreement. If the Software is an update or has been updated, any transfer must include the most recent update and all prior versions.
TERMINATION
This Agreement is effective until terminated. Davis may terminate this Agreement at any time upon your breach of any of the provisions hereof. Upon termination of this Agreement, you will immediately cease all use of the Software, and return to Davis all copies of the Software and Documentation. You will be liable to Davis for all damages suffered as a result of that breach. Except for the license granted herein and as expressly provided herein, the terms of this Agreement will survive termination.
CHANGED PRODUCT FEATURES AND TERMS
Davis has the right at any time to change or discontinue any aspect or feature of the Software and/or services offered by Davis, including, without limitation, the content, the equipment needed for access, or use of the service, or the Software itself. Davis also has the right at any time to change or modify the terms and conditions applicable to use of the Software, or any part thereof, or to impose new conditions, including, without limitation, adding fees and charges for use for services that are currently free or adding or removing Data upload partners, including, but not limited to, CWOP, GLOBE and any others. Such changes, modifications, additions or deletions shall be effective immediately upon notice thereof, which may be given by any means including, without limitation, posting on www.DavisNet.com or any other Davis website, or by electronic or conventional mail, or by any other means. Any use of the Software or services by you after such notice shall be deemed to constitute acceptance of such changes, modifications, additions or deletions.
LIMITED WARRANTY
Davis warrants to the original end user of the Software that (a) the Software will perform substantially in accordance with the documentation provided by Davis, as modified by Davis from time-to-time (“Documentation”) for a period of ninety (90) days from the date of receipt and (b) any Davis hardware accompanying the Software will be free from defects in material and workmanship under normal use and service for a period of ninety (90) days from the date of receipt. This warranty will be void if you breach this Agreement or if the Software has been modified, tampered with, or improperly used.
DISCLAIMER OF WARRANTIES
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE LAW, DAVIS DISCLAIMS ALL OTHER WARRANTIES, WHETHER EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT, AND ANY WARRANTIES THAT MAY ARISE OUT OF COURSE OF PERFORMANCE, COURSE OF DEALING OR USAGE OF TRADE, WITH REGARD TO THE SOFTWARE, SERVICES, DOCUMENTATION, AND THE ACCOMPANYING HARDWARE. DAVIS DOES NOT WARRANT THAT THE SOFTWARE WILL OPERATE IN COMBINATION WITH HARDWARE, SOFTWARE, SYSTEMS OR DATA NOT PROVIDED BY DAVIS, EXCEPT AS EXPRESSLY SPECIFIED IN THE DOCUMENTATION, OR THAT THE OPERATION OF THE SOFTWARE WILL BE UNINTERRUPTED OR ERROR-FREE.
LIMITATION OF LIABILITY
To the maximum extent permitted by applicable law, in no event will Davis be liable for any indirect, incidental, special, consequential or punitive damages, or damages for business interruption or loss of profits, revenue, business, savings, data, information, use or cost of substitute procurement, incurred by you or any third party, whether in an action in contract or tort, even if Davis has been advised of the possibility of such damages or if such damages are foreseeable. In no event will Davis’s liability for damages hereunder exceed the amounts actually paid by you to Davis for the Software and/or Davis hardware. The parties acknowledge that the limitations of liability and the allocation of risk in this Agreement are an essential element of the bargain between the parties, without which Davis would not have entered into this Agreement. Davis’s pricing reflects this allocation of risk and the limitation of liability specified herein.
WARRANTY SUPPORT
You must report to Davis, promptly in writing, any breach of the express warranties set forth above during the warranty period. Your sole and exclusive remedies, and Davis’s entire liability, for such a reported breach will be to correct or provide a reasonable workaround for any errors that caused the breach of warranty, or if Davis is unable to make the Software operate as warranted, you will be entitled to terminate the Software license and recover the fees paid to Davis for the Software license. Davis will have no obligations under the warranty provision set forth above if the breach of warranty is caused by abuse, misuse, alteration, neglect or accidental damage of the Software; the unauthorized repair, modification or installation of the Software; or the use or attempted use of non-Davis software or hardware in combination with the Software. Replacement or repair of Software does not extend its warranty period beyond the original warranty expiration date.
PROTECTION OF INTELLECTUAL PROPERTY RIGHTS
Davis retains all rights, title and interest in the Software, Data, Content and proprietary products owned by Davis, including, without limitation, copyright and trademark rights in the Software, Data and Content, the Weatherlink and Weatherlink.com trademarks, and other trademarks, service names, symbols, identifiers, URL's, formats, designs, and devices. The Software, Data and Content, and all rights thereto, are the property of Davis and are protected by applicable copyright or other law. The customer shall not claim any rights, including, without limitation, trademark or copyrights in any Software, Data or Content.
GOVERNING LAW AND JURISDICTION
This Agreement and all matters arising out of or relating to this Agreement will be governed by the internal laws of the State of California without giving effect to any choice of law rule. This Agreement will not be governed by the United Nations Convention on Contracts for the International Sales of Goods, the application of which is expressly excluded. In the event of any controversy, claim or dispute between the parties arising out of or relating to this Agreement, such controversy, claim or dispute may be tried solely in a state or federal court for Alameda County, California, and the parties hereby irrevocably consent to the jurisdiction and venue of such courts.
ENTIRE AGREEMENT
This Agreement constitutes the entire agreement between the parties and supersedes all prior or contemporaneous agreements or representations, written or ..., concerning the subject matter of this Agreement. This Agreement may not be modified or amended except in a writing signed by a duly authorized representative of each party; no other act, document, usage or custom will be deemed to amend or modify this Agreement. It is expressly agreed that the terms of this Agreement will supersede the terms in any purchase orders or other ordering documents.
SEVERABILITY
If any provision of this Agreement is held to be illegal, invalid or otherwise unenforceable, such provision will be enforced to the extent possible consistent with the stated intention of the parties, or, if incapable of such enforcement, will be deemed to be severed and deleted from this Agreement, while the remainder of this Agreement will continue in full force and effect. The waiver by either party of any default or breach of this Agreement will not constitute a waiver of any other or subsequent default or breach.
NO ASSIGNMENT
You may not assign, sell, transfer, delegate or otherwise dispose of, whether voluntarily or involuntarily, by operation of law or otherwise, this Agreement or any rights or obligations under this Agreement without the prior written consent of Davis. Any purported assignment, transfer or delegation by you will be null and void. Subject to the foregoing, this Agreement will be binding upon and will inure to the benefit of the parties and their respective successors and assigns.
EXPORT ADMINISTRATION
You will comply fully with all relevant export laws and regulations of the United States, including, without limitation, the U.S. Export Administration Regulations (collectively “Export Controls”). Without limiting the generality of the foregoing, you will not, and you will require your representatives not to, export, direct or transfer the Software, or any direct product thereof, to any destination, person or entity restricted or prohibited by the Export Controls.
PRIVACY POLICY
The use of personal information by this Software is governed by Davis privacy policy. To see this policy, visit http://www.davisnet.com/about/privacy.asp
So, habe darauf hin mal komplett die Software WeatherLink vom system entfernt, und auf Direktbetrieb WsWin VP2 umgestellt!
Doch das Problem besteht weiterhin, obwohl alle Dateien von WeatherLink entfernt sind! Sowohl am PC wie auch auf dem Server!
Seit der Umstellung von WS2500 auf VP2 ist das Problem vorhanden!
Weiß von euch jemand Rat an was das liegen könnte?? Habe damals die WeatherLink-Software richtig und vollständig install.!
GRANT OF LICENSE
TERMINATION
LIMITED WARRANTY
WARRANTY SUPPORT
ENTIRE AGREEMENT
SEVERABILITY
NO ASSIGNMENT
PRIVACY POLICY
Wettermichel
Oliver47
Wettermichel
Oliver47
also auf meinem Rechner sind die Daten korrekt! Es werden auch alle Customfiles korrekt abgearbeitet!
Hier mal ein Link:
http://www.wetter-uffing-murnau.de/wett ... piegel.txt
http://www.wetter-uffing-murnau.de/wett ... _werte.txt
Alle Dateien werden korrekt abgearbeitet!
Hier mal ein Link:
Zuletzt geändert von Oliver47 am 02 Sep 2008 20:13, insgesamt 1-mal geändert.
Wettermichel
das Problem hängt hier anscheinend mit dem Upload zusammen.
Gehe ich recht in der Annahme das Du den HS_Uploader oder den kleinen Bruder davon im Einsatz hast?
Ist der Uploader im WsWin Verzeichniss Installiert?
Wie hast Du die Dateien die seinerseits von Weather-Link erstellt wurden hochgeladen?
Hast Du eventuell FileZilla als Uploader zur Hand?
Wenn Ja mach mal folgendes.
Lösche mit FileZilla die betreffenden Textdateien auf dem Server.
Lade anschließend Probehalber mit FileZilla die Textdateien hoch.
Werden die Dateien dann richtig dargestellt, gehen wir zum nächsten Schritt über.
Schalte solange mal den HS-Uploader aus. wichtig!
Oliver47
ja verwende den HS-Uploader!
Dieser ist jedoch nicht im WsWin Ordner verzeichnet sondern unter Programme!
Ich habe noch den FTP-Uploader! Teste mit diesem mal!
Habe alle Dateien erneut vom Server gelöscht! Doch nach erneutem Hochladen mit HS-Upload wurde der Text wie oben beschrieben wieder aufgeführt!
Wettermichel
Oliver47
Wettermichel
genau so ist es.
Vorschlag Deinstalliere den HS_Uploader.
Starte den Rechner neu und Installiere anschließend den HS-Uploader neu aber unter Laufwerk C: und nicht im Programmordner.
Anschließend an der Datei HS_Upload.exe Datei unter Eigenschaften folgendes Einstellen Archiv und Indexartribute den Punkt "Datei kann Archiviert werden" deaktivieren.
Als nächstes noch dafür Sorgen das der Virenscanner das Verzeichniss von HS-Upload nicht indiziert bzw. Überwacht.
Danach eine Testlauf Manuell starten und schauen was passiert.
Michael
genau so ist es.
Michael
Oliver47
habe deinen Vorschlag mal befolgt, und es so gemacht wie Du es beschrieben hast!
Resultat daraus ist, dass genau der gleiche Text wie oben auch wieder kommt!
Das heißt zumindest für mich, dass hier der HS-Uploader zumindet bei mir fehl am Platze ist!
Bleibe nun bei FTP-Upload denn hier gibt es keinerlei Probleme!
Sollte dies bei anderen auch so sein, dann wechselt mal!
Ich kann jetzt nur von meiner Lage aus sprechen, und stelle halt nun mal fest, dass es mit HS-Upload nicht funktioniert!
Daher wird dieser bei mir komplett vom System entfernt!
