Hi all,
Sorry my message is in english.
I have my WsWin exported to a new pc Acer, running Windows 7, home premium.
Everything works even better than under XP, except for de mini-graphics and the instruments. I'm certain I have ticked everything under internet/adjustments, and even more, I compared the WSWIN.CFG line by line between the two pc's. No differences were noted. Not a single mini grafik is created, nor the individual instruments.
I tried even your latest version, but I had to revert to version 2.91.7, stable for years now, and with the advantage that up to now, it is the only version that auto-restart in case of "no data received".
Could my problem be related to Windows 7???
Thanks for any suggestion!
Marc
Windows 7
DC.Kraft
Marc
Danke Dieter,
Ihren English ist perfect für mich. Sie können freilich antworten in Deutsch, ich verstehe es, aber schreiben....
Your suggestion is no solution. The results in directory C:\PROGRAM FILES (x86)\WsWin or in C:\WsWin are the same. Every html file and aktuell.gif function normally. Only the mini-grafics (mini_currentt.gif, mini_currentt2.gif etc.) and the individual instruments (instr_t.gif, instr_w.gif etc) are missing. Alle the rest is perfect, even the statistics.
The program is run in Windows XP SP2 mode.
Hope someone can find a solution.
Vielen Danke
Marc
Vielen Danke
Marc
Marc
Ende
Hello all,
I have done a clean install of WsWin ver 2.95.11 under c:\WsWin. Both trials (in XP SP2 as in normal mode gave the same result: all files are written normally, except for the mini graphics and the instruments.
I have certainly the hook at "Internet - adjustments - graphiics" and there "instruments create" set?
As I am a little saturated with those problems, I decided to remove Windows 7 and return back to Windows XP, where the program runs error free since 2001!!! Why complicate things further???
Thanks to all who were so friendly to try to solve my problem.
Marc
Marc
