Warnung vor Starkregen mittels Varibalen
Danksagung erhalten: 47 mal
Da die Regensaison eröffnet ist, hier mal wieder etwas nützlichen zwischendurch: Die Starkregenwarnung.
Sie gibt folgende Warnungen aus:
-keine Warnung
-Achtung! Warnung vor Starkregen >25mm/h
-Achtung! Warnung vor Dauerregen >25mm/6h
-Achtung! Warnung vor Dauerregen & Starkregen >35mm/6h
Zusatz hintendran (nur bei Dauerregen):
-nachlassend
<tr><td width="22%" height="46"><font color="#4F576C"><b><nobr>Warnung v. Starkregen*</nobr></b></font></td>
<td align="center" width="7%" height="46"><img border="0"
%unit_off%
%ws_setmem[1]=%ws_compare[2]=%rainrate%~10.0~1~0%%
%ws_setmem[2]=%ws_compare[2]=%curminmaxhour[4,1,34]%~15.0~1~0%%
%ws_setmem[3]=%ws_calc[+]=%ws_getmem[1]%~%ws_getmem[2]%~1%%
%ws_setmem[4]=%ws_compare[2]=%curminmaxhour[4,6,39]%~180~1~0%%
%ws_setmem[5]=%ws_calc[+]=%ws_getmem[3]%~%ws_getmem[4]%~1%%
%ws_setmem[6]=%ws_compare[2]=%curminmaxhour[4,1,39]%~20~1~0%%
%ws_setmem[7]=%ws_calc[+]=%ws_getmem[5]%~%ws_getmem[6]%~0%%
%ws_compare[2]=%ws_getmem[7]%~2~src=Starkregen1.gif~src=no_ice.gif%
%unit_on% width="50" height="50"></td>
<td align="center" width="52%" height="47" colspan="7"><b><font size="3"><nobr>
%unit_off%
%ws_setmem[3]=%ws_calc[+]=%ws_getmem[1]%~%ws_getmem[2]%~0%%
%ws_setmem[4]=%ws_compare[2]=%curminmaxhour[4,6,39]%~180~3~0%%
%ws_setmem[5]=%ws_calc[+]=%ws_getmem[3]%~%ws_getmem[4]%~0%%
%ws_setmem[6]=%ws_compare[2]=%curminmaxhour[4,1,39]%~20~3~0%%
%ws_setmem[8]=%ws_compare[3]=%valuechange[39]=30%~0.0~3~0%%
%ws_setmem[9]=%ws_calc[+]=%ws_getmem[7]%~%ws_getmem[8]%~0%%
%ws_compare[3]=%ws_getmem[7]%~0~<font color="#4F576C">&#8658 keine Warnung~%
%ws_compare[3]=%ws_getmem[7]%~1~<font color="#4F576C">&#8658 keine Warnung~%
%ws_compare[3]=%ws_getmem[7]%~3~<font color="#4F576C">&#8658 keine Warnung~%
%ws_compare[3]=%ws_getmem[7]%~2~<font color="Red"><span style="background-color: yellow;">Achtung! Warnung vor Starkregen >25mm/h</span>~%
%ws_compare[3]=%ws_getmem[7]%~4~<font color="Red"><span style="background-color: yellow;">Achtung! Warnung vor Starkregen >25mm/h</span>~%
%ws_compare[3]=%ws_getmem[7]%~5~<font color="Red"><span style="background-color: yellow;">Achtung! Warnung vor Starkregen >25mm/h</span>~%
%ws_compare[3]=%ws_getmem[7]%~6~<font color="Red"><span style="background-color: yellow;">Achtung! Warnung vor Dauerregen >25mm/6h</span>~%
%ws_compare[3]=%ws_getmem[7]%~7~<font color="Red"><span style="background-color: yellow;">Achtung! Warnung vor Dauerregen & Starkregen >35mm/6h</span>~%
%ws_compare[3]=%ws_getmem[7]%~8~<font color="Red"><span style="background-color: yellow;">Achtung! Warnung vor Dauerregen & Starkregen >35mm/6h</span>~%
%ws_compare[3]=%ws_getmem[9]%~9~<font color="Blue">&#8658 nachlassend~%
%unit_on%
</nobr></font></b></td></tr>
Das Icon muß: Starkregen1.gif heißen und direkt im WSWIN-html-Ordner liegen.
Kann man hier kopieren, oder ein eigenes verwenden:
http://www.woldegk-wetter.de/Starkregen1.gif
Die Warnung springt an und warnt vor:
Starkregen >25mm/h bei
-einer Regenrate >10,0mm + >15,0mm Regen in der letzten 1h (2)
-einer Regenrate >10,0mm + 180 Minuten Regenzeit in den letzten 6h (4)*
-180 Minuten Regenzeit in den letzten 6h + >15,0mm Regen in der letzten 1h (4)
-20 Minuten Regenzeit in der letzten 1h + >15,0mm Regen in der letzten 1h (4)
-20 Minuten Regenzeit in der letzten 1h + einer Regenrate >10,0mm (4)
-einer Regenrate >10,0mm + >15,0mm Regen in der letzten 1h + 20 Minuten Regenzeit in der letzten 1h (5)*
-einer Regenrate >10,0mm + >15,0mm Regen in der letzten 1h + 180 Minuten Regenzeit in den letzten 6h (5)*
:idea: *) diese Optionen sind eher nur theoretisch bzw. kurzzeitg möglich, da bei einer RR >10mm und/oder 15mm/1h auch die Regenzeit bei >20 Minuten liegt, weshalb dann Dauerregen + Starkregen greifen würde. Sie füllen also nur eine evtl. Zeitlücke, bis eine andere Warnungnummer mit gleichem Text greift - was aber für das Ausgabeergebnis keinerlei Relevanz hat.
Dauerregen >25mm/6h bei
-180 Minuten Regenzeit in den letzten 6h + 20 Minuten Regenzeit in der letzten 1h (6)
Dauerregen + Starkregen >35mm/6h bei
-einer Regenrate >10,0mm +180 Minuten Regenzeit in den letzten 6h + 20 Minuten Regenzeit in der letzten 1h (7)
->15,0mm Regen in der letzten 1h + 180 Minuten Regenzeit in den letzten 6h + 20 Minuten Regenzeit in der letzten 1h (7)
-einer Regenrate >10,0mm + >15,0mm Regen in der letzten 1h + 180 Minuten Regenzeit in den letzten 6h + 20 Minuten Regenzeit in der letzten 1h (acht)
Es ist also zwingend nötig den Zeitsensor ID39=Regenzeit scharf zu schalten.
Die Warnung wird also aktiv, wenn entweder Dauerregen herrscht, oder Starkregen mit sehr hoher Regenrate - oder beides kombiniert. Es ist eine Hochrechnung in die nahe Zukunft (sonst würde eine Warnung ja nichts nutzen). Je nach Regenmesser und Meßintervall müssen die Schwellwerte evtl. angepaßt werden. Ich habe eine Regenmesserauflösung von 0,25mm, sowie ein Meßintervall von 5 Minuten. Wichtiger wie die Auflösung, dürfte jedoch das Meßintervall sein, da es entscheidend für die Regenrate ist. Je kleiner das Meßintervall (Ausleseintervall), desto größer fällt evtl. die Regenrate aus.
Durch die Kombination von mindestens zwei Grundvariablen wird erreicht, daß die Warnung aus geht, sobald ein Kriterium nicht mehr vorhanden ist. Andererseits reicht es nicht, wenn es bei Dauerregen zwischendurch mal 1/4h trocken ist, um Entwarnung zu geben.
Dann mal viel Spaß beim Gartenschlauchtest....
8)
Zuletzt geändert von Tex am 28 Apr 2015 13:14, insgesamt 3-mal geändert.
Danksagung erhalten: 17 mal
Hi Tex:
Starkregen wird aber mit einem "r" geschrieben! (gif-Bild) :)
Na Donnerwetter - das hatte ich noch gar nicht gesehen! In der Custom ist es eh so klein, daß man das kaum lesen kann....
@all
ganz unten in der Starkregenwarung hatte ich vergessen diese beiden Variablen herauszunehmen:
%curminmaxhour[4,8,39]% / %ws_getmem[9]%
Das waren nur Kontrollvariablem, die zeigen die Nummern an. Bitte löschen.
Mado
Danksagung erhalten: 19 mal
Beitrag von Mado »
Und schief ist die Schrift auch noch. :)
11klausdieter
Beitrag von 11klausdieter »
Hallo Manfred,
ich kann hier nicht ganz nachvollziehen, wie DU hier Kritik übst. Der Hinweis auf einen Rechtschreibfehler ist ja ok, aber den Rest hätte man auch anders schreiben können.
Wir User sollten froh sein, dass es User gibt, die etwas kreatives zu Gesamt-Thema Wetter beitragen und dies auch noch mit anderen Usern teilen.
Mado
Beitrag von Mado »
Hier handelt es sich um einen Spaß !! Wer das nicht versteht oder anders sieht, kann ich somit nicht weiter helfen. Auch durch den Satz ist keine Kritik geübt worden !
...ich hatte den Spaß schon verstanden. :D
