I use WsWin32 2.91.4 with Weatherlink but it is somewhat of a nuisance because every time Weatherlink archives (set to 5 minute interval) WsWin32 takes over the screen and displays the graphs even though I have it minimized. In the past I had it running on a separate PC, however lightning terminated that and now I have to run everything on one PC.
How can I keep the program from maximizing during updates.
Display update
Hello,
there is only one way (it's a workaround), which I have described on my page
http://www.wernerneudeck.de/wetter/faqprobs/index.html
in "Wie erreiche ich, dasss..." the term "Aktualisierung"
I hope, you can understand some german, when not, post again.
Dragonfly
As I understand it, translation a little rusty.
To prevent WSWin from popping up to the foreground of the screen when updating,
go to Internet – Adjustment and on the Common Tab check not aktuell.gif. In the aktuell.gif box force the popup to your preferred timeframe. Select X to never update.
This setting only has an effect on the current screen and the Instruments gif files.
Those settings seam to work.
Thank
Thank
