Wie macht Ich den data.xml
Fredens
Beitrag von Fredens »
Hallo Freunde,
Meine deutsch ist nicht gut so Ich hoffe englisch im Forum ist okay und dass einer in englisch anworte kann.
Danke in vorraus
I would like to make a xml feed of my weather data, but reading all the german technial text (and somewhat cofusing english manual) I'm quite in doubt in how to do it so I hope someone here can help me.
I've managed to make a wml file, but I would also like to make a xml file.
Hoping for an answer
Der Däne
rabit
Beitrag von rabit »
Hi,
you need a file like thie http://aktuell.mannheim-wetter.info/rss.xml.
To generate such a file use the custom file engine for the WAP files but don´t use wml spezific tags. The WAP file engine generates files without additional (html..) tags.
Viele Grüße aus Mannheim
gerhard
Fredens
Hi,
Thanks for answering!
Is it possible that you could post the first 10-15 lines of a wap.txt file that generates a xml file. Just so I can get an idea?
Thanks
rabit
Beitrag von rabit »
wap.txt: (generates the file wetter.wml, opens the second template rsscript.txt)
%customfile=wetter.wml%
%openfile=rssscript.txt%
///<xml>
///<!DOCTYPE wml PUBLIC "-//WAPFORUM//DTD WML
......code for the wetter.wml file
The second template:
rssscript.txt (generates the file data.xml, and opens the third template rss2script)
///<customfile>
%openfile=rss2script.txt%
%unit_on%<xml>
///<xml>
///<rss>
<channel>
<title>Wetterwerte aus Mannheim</title>
<link>http&#58;//www.mannheim-wetter.info</link>
<description>Das Wetter aus Mannheim und Umgebung mit Daten der eigenen Wetterstation und WebCam</description>
<language>de-de</language>
<copyright>2004 mannheim-wetter.info</copyright>
<image>
<url>http&#58;//www.mannheim-wetter.info/wetter/pcws/%forecast_icon%</url>
<title>Aktuelles Wetter</title>
</image>
<item>
<title>%ws_time%&#58; Temperatur&#58; %curval&#91;2&#93;% </title>
<description>Am %ws_date% um %ws_time% lag die Außentemperatur bei %curval&#91;2&#93;%. Änderung in der letzten Stunde&#58; %curminmaxhour&#91;4,1,2&#93;%.</description>
</item>
<item>
<title>%ws_time%&#58; Luftdruck&#58; %curval&#91;33&#93;% </title>
<description>Am %ws_date% um %ws_time% Uhr war der Luftdruck bei %curval&#91;33&#93;%. Die Änderung betrug %ws_baro3h%. </description>
<link>http&#58;//cam.mannheim-wetter.info</link>
</item>
<item>
<title>%ws_time%&#58; Niederschlag&#58; %rainday% </title>
<description>Am %ws_date% um %ws_time% Uhr gab es seit Mitternacht %rainday% Niederschlag. Innerhalb der letzten 24h waren es %rain24h%. Im aktuellen Monat waren es bis jetzt %rainmonth%</description>
<link>http&#58;//grafik.mannheim-wetter.info</link>
</item>
<item>
<title>%ws_time%&#58; Vorhersage&#58; %forecast_txt% </title>
<description>Basierend auf den aktuellen Temperatur und Luftdruckwerten soll es innerhalb der nächsten 24h %forecast_txt% werden.</description>
<link>http&#58;//www.mannheim-wetter.info/vorhersage.shtml</link>
</item>
</channel>
</rss>
The first wap-template is always a file called "wap.txt"!
The lines with "///" are wrong. However. Take a look in my original rss.xml for the correct code.
gerhard
Fredens
I still dont get it - sorry
Here is my the first part of my wap.txt
%customfile=index.wml%
%openfile=data.txt%
<?xml version="1.0" encoding="ISO-8859-1" ?>
<!DOCTYPE wml PUBLIC "-//WAPFORUM//DTD WML 1.1//EN" "http&#58;//www.wapforum.org/DTD/wml_1.1.xml">
<wml>
  <card id="Aktuell" title="%ws_location%">
    <p align="left">
           <b><big>Fredensvejr</big></b><br/>
Here is the first part of the data.txt file:
%unit_on%<xml>
  %customfile=fredens.xml%
<!--  encoding="UTF-8" internationaler CharSet auf Basis der ISO/IEC-10646-Norm mit 8 Bit Zeichenbreite  -->
<!--  encoding="UTF-16" internationaler CharSet auf Basis der ISO/IEC-10646-Norm mit 16 Bit Zeichenbreite -->
<!--  encoding="ISO-8859-1"  ISO-CharSet westeuropaeische Sprachen  -->
<!--  encoding="ISO-8859-2"  ISO-CharSet osteuropaeische Sprachen  -->
<!--  encoding="ISO-8859-3"  ISO-CharSet südeuropaeische Sprachen  -->
<!--  encoding="ISO-8859-4"  ISO-CharSet nordeuropaeische Sprachen  -->
<!--  encoding="ISO-8859-5"  ISO-CharSet kyrillische Sprachen siehe  -->
<!--  encoding="ISO-8859-6"  ISO-CharSet arabische Sprachen siehe  -->
<!--  encoding="ISO-8859-7"  ISO-CharSet griechische Sprache siehe  -->
<!--  encoding="ISO-8859-8"  ISO-CharSet hebraeische Sprache siehe  -->
<!--  encoding="ISO-8859-9"  ISO-CharSet tuerkische Sprache siehe  -->
<!--  encoding="ISO-8859-10" ISO-CharSet nordische Sprache  -->
<WXDATA>
 <PARAM>
<!--  List of supported variables / Liste der unterstützen Variablen .............................   -->
<!--  %shortslabel&#91;x&#93;%  -->
<!--  %longslabel&#91;x&#93;%  -->
<!--  %curval&#91;x&#93;%  -->
But all it does is (make the index.wml which is ok) but also a custom.wml with the data that should be an xml file with the name of "fredens.xml".
Many thanks for your patience ;-)
rabit
Beitrag von rabit »
%customfile.... muss be in the first line!
%openfile.... in the second
and then the rest.
gerhard
Fredens
Fantastic!!
It works!
http://www.elgum.dk/vejr/fredens.xml
Thanks a lot :D
