For some reason WsWin wont start Recording. Ive set File->Options ->Parameters to "Automatic Start Recording at Start up" and "In this case, automatic import/convert data" - I use WS2300. I've also choosen the right History.dat file in the "ConvertPC_WS file" option.
Even if I manually Convert data, and afterwards pressing the "Recording start" button Wswin wont start recording.
Hello Fredens,
have a look at "weather station - interface type" and there at "file watching"
Have you chosen here the right filename and set hooks at "before convert data" and "watching active"
And you should also choose about 5 or 6 seconds at the end of the line.
