Hi Werner,
Just to let you know that I stumbled on some small errors in the english version of WSWIN.
I discovered when playing around with my brandnew solarsensor from Jürgen: seems to be marvellous.
In the Display bar, under the solar sensor is the status of the clouds given as "cloudedly", must be "cloudy".
Also in the Display bar is the Dewpoint abbreviation "TP" (from Taupunkt?) instead of DP.
In several HTML examples is the height above sealevel given as "height "over" sealevel" (from über??).
You see, nothing serious but as you are a perfectionist...
Vielen Dank
Marc
Cosmetic corrections
