wunderground start- eand endtime
Verfasst: 10 Apr 2006 08:19
von Louis
Hi,
i use wswin to upload my weatherdata to wunderground once a day (every evening).
When I upload data, I see that a day is between 22.00 yesterday and 21.00 today (for every day) and that data is uploaded until the current time minus 2 hours.
1) Is it possible to change the start-time and end-time for a day for the upload for wunderground to times that are more convenient to me (eg 17.00 yesterday - 18.00 today)?
2) Why isn't the data uploaded until the last hour?
Best regards,
Louis
Verfasst: 10 Apr 2006 08:42
Hello Louis,
I think, this is no real problem, because you will lose no data, if you do it every day. The upload starts the day before and it uploads all data till to the current day. The time difference results of GMT and summertime.
Once again to your problem:
When you start uploading at 17:00, you will lose no data.
And when you have missed a day, you choose the week-view in WSWIN and the data will be upoadede for the whole week.
Verfasst: 12 Apr 2006 08:21
von Louis
Hi Werner,
you can see what I mean on this page: http://www.wunderground.com/weatherstat ... 06&month=4
So "you will lose no data, if you do it every day" is not true, as you can see on the first graph. There is a gap after 18.00 (every day)
And "The upload starts the day before and it uploads all data till to the current day" is not true as well; there is data for the period between 18.00 and 01.00 the next day (the gap) but it isn't uploaded!
Did you try this by yourself?
So my question is still:
Best regards,
Louis
Verfasst: 12 Apr 2006 09:00
Hello,
it seems, that there is a difference to my way.
I do it automatically the day over from 8:00 to 23:00
The next day I transfer the missing values as you do and there are submitted the values from 23:00 until current time of the next day.
So I fear, only Werner can help you.
Verfasst: 12 Apr 2006 09:35
von Louis
OK thanks,
I'll await his response.
Regards,
Louis
Verfasst: 12 Apr 2006 11:24
@Louis,
there are two solutions:
1) use week view and send here the data
2) select under the 24hour view the starting time to 02:00 and send then for the current day (+02:00 the difference to the UTC Time)
