Bugs in wswin32 2.93.5 with Davis VP2
Verfasst: 18 Okt 2006 12:59
von Arcibald
Hi,
Found bug in wswin 2.93.5, with it I use of 2 sensors temperature the Tmax is always equal
Regards
Verfasst: 18 Okt 2006 23:05
Hello,
please can you show your Min./Max table
Create it:
Select View, Minimum and maximum...
double click in the table
a file minmax_yyyymmdd.gif will be created.
Verfasst: 19 Okt 2006 08:27
von Arcibald
Error in Tmax
Error in Tmax
Error in Tmin
Error in Tmax
:cry: :cry:
Verfasst: 19 Okt 2006 22:32
@Arcibald,
I can't find any incongruity.
On some days the Tmin is equal, on other days the Tmax is equal.
Verfasst: 21 Okt 2006 12:52
von Arcibald
Excuse but for me there is a bug in the software :cry:
Here there are the values read from the sensors and are different !!
http://www.meteopiateda.it/Piateda/PC/20061016.htm
Best regards
Verfasst: 21 Okt 2006 16:46
Hello
the table shows the same values - so where is is the difference?
Verfasst: 21 Okt 2006 17:16
von Arcibald
Hello,
The difference is that the Tmax recorded to 2 meters it is not 19.3° to the 13,54, but 18.9° recorded to the 13,32. An error of software in bringing back is obvious therefore such data.
Martin
Verfasst: 21 Okt 2006 23:35
What is your dew point sensor?
It seems that you use for dew point (= main outdoor sensor)
the sensor "Temperatura esterna 10 m"
So it is correct.
Verfasst: 22 Okt 2006 23:28
von Arcibald
Hello Werner
In quarter column of http://www.meteopiateda.it/Piateda/PC/20061016.htm ( T.Est 2m.) I never do not see 19.3°C unless in “massima” line.
It is mistaken because the tmax 2m of the 16/10/2006 it is 18.9°C.
The timetable of the "Max-Ora" (2m sensor) is mistaken because the Tmax 2m it has been recorded to the 13,32.
Martin
Verfasst: 23 Okt 2006 07:00
@Martin,
I didn't assume that someone uses for
main outdoor temperature a second (extra) temperature sensor,
which isn't so accurately and has a only resolution of ~0.5 °C
You are right, Wswin merges the min/max values from the
standard outdoor sensor to this sensor.
I will correct that.
Verfasst: 23 Okt 2006 07:50
von Arcibald
Werner hat geschrieben:@Martin,
It does not appeal to not even me this solution, but in order not to leave in shadow the solar sensors, I have had to install the iss on the house roof and to put an extra sensor in garden.
Thank you.
Martin
