changes some properties are not saved
Verfasst: 14 Nov 2006 20:27
von alexxxander1
Hello,
Can anybody help me with this problem?
When I change some of the properties for Internet, for example “HTML Folder” and than close the program, start again. All the changes are gone and back to default.
What can I do to save the changes?
Well thanks in advance.
Alexander
The Netherlands
Verfasst: 14 Nov 2006 20:51
von jekno
Hi!
Do you have write-rights on the wswin-folder and the files incuded?
or
You habe copied the WsWin-Files from a backup on cdrom?
Then you must change the file-attributes from write-protect.
Verfasst: 14 Nov 2006 21:24
von alexxxander1
jekno hat geschrieben:Hi!
or
Hi jekno,
Thanks, but write-rights are not the problem.
The funny thing is that if I change the field “Wap Folder” (internet settings) and restart the program the changes are remembered but if I do the same for “HTML Folder” than the changes are lost when I restart the program.
Alexander.
Verfasst: 14 Nov 2006 23:12
Hello,
try the following:
Do not close the programm by "X", but use "File - quit programm"
Perhaps it helps.
Verfasst: 14 Nov 2006 23:42
zur Info für Euch:
Alexander verwendet die "nicht registrierte Version".
Und hier ignoriert das Programm nach einem Neustart
viele der vorher gemachten Einstellungen unter "Internet".
Hab das Alexander gemailt.
