CURRENT.HTML file
flax
CURRENT.HTML file
I try to make my own current.html file. When I change something in CURRENT.TXT file, nothing happends and WsWin32 still generate his own, not modified file. Please can anyone help me how to change it? Thank you
Helo,
you must rename the current.txt to custom.txt
Then WSWIN will create a file called custom.html
All changes, you have made in custom.txt, you will see in custom.html
The first line in the custom.txt must be
And you have to enable it by setting the hook at "Internet - Adjustments - Common" at "update customizes html files in record mode"
flax
flax
flax
Thank you, now it works great, I think this is the best meteo SW available especially thanks to creating fully customizable html pages. It's pity that it's not possible to create fully customizable minidisplay.gif with fonts and position settings including variables. There is but only one big problem with screen capturing and window popuping when aktuell.gif is created. When it will be fixed I buy it immediately. Thank you for your help!
