CURRENT.HTML file
Verfasst: 01 Dez 2006 21:49
von flax
I try to make my own current.html file. When I change something in CURRENT.TXT file, nothing happends and WsWin32 still generate his own, not modified file. Please can anyone help me how to change it? Thank you
Verfasst: 01 Dez 2006 23:05
Helo,
you must rename the current.txt to custom.txt
Then WSWIN will create a file called custom.html
All changes, you have made in custom.txt, you will see in custom.html
The first line in the custom.txt must be
<!-- %customfile=custom.html% -->
And you have to enable it by setting the hook at "Internet - Adjustments - Common" at "update customizes html files in record mode"
Verfasst: 02 Dez 2006 02:05
von flax
Thank you! That helps me! I have only problem that creation of CUSTOM.HTML file isn't very regular, sometimes when i restart WsWin it's created and than it stays in same format even i'm changing CUSTOM.TXT file. How can I invoke CUSTOM.HTML generation manually in WsWin32?
Verfasst: 02 Dez 2006 03:52
von flax
I found in menu Internet item "Customized HTML/WML" which can create CUSTOM.HTML manually, but still I have problem generate it automatically and sending it to Internet through FTP.
Verfasst: 02 Dez 2006 10:29
Hello,
When you do, what I have posted above
it will be done automatically.
Verfasst: 02 Dez 2006 16:04
von flax
Thank you, now it works great, I think this is the best meteo SW available especially thanks to creating fully customizable html pages. It's pity that it's not possible to create fully customizable minidisplay.gif with fonts and position settings including variables. There is but only one big problem with screen capturing and window popuping when aktuell.gif is created. When it will be fixed I buy it immediately. Thank you for your help!
