Rain Quantity
Verfasst: 15 Jan 2007 20:51
von fcorey
Hello,
I have a Vantage Pro2 and when I use WsWin to read directly from the datalogger I get bad rain quantity data (the reported values are much less than the actual values). When I use WeatherLink file watching the rain quantity values are correct. I have not been able to figure out how to correct this problem.
Thank you,
Fred.
Verfasst: 15 Jan 2007 22:45
Helo Fred,
have you already controlled "weather station - adjustments" and here the rain-sensor type? Normally it's 0,01 in, but when you have installed the metric adapter, it's 0,2mm
And have also a look at "weather station - calibrate rain quantity", if there is used the calibration-factor 1.000
Verfasst: 16 Jan 2007 00:22
von fcorey
Werner,
Thank you for the fast reply. That has corrected the rain quantity problem!
Thank you,
Fred
