Wind correction.
Verfasst: 08 Feb 2007 17:16
von Ryant
Hi, I recently got this great program but am confused with the wind correction. I need to build in a 10% correction increase on actual wind speeds and gusts (due to where I have sited the equipment). Do I enter a figure in the first box or the second next to the +/- uncer file-properties?
Thanks for any help.
Ryan
Verfasst: 08 Feb 2007 18:18
Hello,
you do it in the first box.
The second box is for a constant value, that means, when you enter "20" in the second box, there will always be entered "20" and not per centage
Correction:
not "there will always be entered" but "there will always be added"
Verfasst: 08 Feb 2007 20:59
@Ryan
enter there at
Sensor calibration x 1.100
(for 10% more)
at +/- 0.00
Verfasst: 09 Feb 2007 10:01
von Ryant
Thanks for your help guys, so entering 0.10 in the first box will increase the wind recorded by 10%, and I should leave the second +/- box as 0.00.
Verfasst: 09 Feb 2007 10:19
Hello,
yes, but you must enter 1,10 and not 0,10
Verfasst: 09 Feb 2007 10:32
von Ryant
Ok, thanks very much.
