WsWin wont start Recording
Verfasst: 10 Feb 2007 09:41
von Fredens
Hi there,
For some reason WsWin wont start Recording. Ive set File->Options ->Parameters to "Automatic Start Recording at Start up" and "In this case, automatic import/convert data" - I use WS2300. I've also choosen the right History.dat file in the "ConvertPC_WS file" option.
Even if I manually Convert data, and afterwards pressing the "Recording start" button Wswin wont start recording.
I've even updated to 2.93.8 but with no avail
Any ideas?
/Fredens
Verfasst: 10 Feb 2007 10:12
Hello Fredens,
have a look at "weather station - interface type" and there at "file watching"
Have you chosen here the right filename and set hooks at "before convert data" and "watching active"
And you should also choose about 5 or 6 seconds at the end of the line.
Verfasst: 10 Feb 2007 15:49
von Fredens
Fantastic!!
Did make a new history.dat file, but forgot to change the name at "File watching" as well.
Thanks a lot
/Fredens
