TXT file generation
Verfasst: 24 Feb 2007 14:48
von flax
Hello!
I have only one question. I need to generate simple TXT file in this format:
DD.MM.YYYY|HH:MM|TT.T|VV|TTTT.T|RR.R|SSS|DD.D|
12.11.2006|14:54|14.2|58|1027.4|1.8|257|0.5|
Date|time|temperature|humidity|presure|wind speed|wind direction|precipitation per 1 hour|
Please is it possible to generate file in this format every 15 minutes. ?
Thank you for your help!
Verfasst: 24 Feb 2007 15:20
Hello,
either you take the "aktuell.txt" as it is, example here
24.02.2007;00:00;20,7;4,2;4,2;4,3;44;90;1009,9;0,000;0,0;96;0;0,000;0,0;0;2,7;4,2;0,0;100,00;0;5;45
24.02.2007;00:05;20,7;4,1;4,1;4,2;44;90;1009,9;0,000;0,0;0;0;0,000;0,0;0;2,6;4,1;0,0;100,00;0;0;45
or you use a user-defined template with the wswin-variables to get exactly, what you want.
Verfasst: 24 Feb 2007 16:06
von flax
Yes I know that there is possibility to create custom template files, but i don't know how to use it. This program is so complex and not very user friendly, please can you explain me this in some step-by-step manual? :)
Verfasst: 24 Feb 2007 16:37
Hello,
You create a file containing the following:
<!-- %customfile=aktuellwert.txt% -->
%unit_off%%ws_date%;%ws_time%;%curval[0]%;%curval[-1]%;%curval[33]%;%curval[35]%;%curval[36]%;%rain1h%
This file you call for example "daten.txt" and store it in the programm-folder.
Then you open the file "wap.txt" (it's in th e programm-folder) and in the second line of this file you insert
<!-- %openfile=daten.txt% -->
and store the file again.
Then the following will happen:
Whenever wswin gets data from your station, it will look for the file "daten.txt" and open it.
Then it will create the file "aktuellwert.txt"
And in this file you will find the actual data.
Be sure that you have set a hook in WSWIN at "Internet - adjustments" and there at "update customized html files in recording mode"
