Last rain
Verfasst: 11 Mär 2007 11:48
von Ryant
When I look at the last rain recorded, it always shows the last few minutes as a time (and under statistics), but nothing recorded. Is there a way for the actual last rain to show instead. See
http://www.cumbriawx.org.uk/current.html.
Thanks guys.
Verfasst: 11 Mär 2007 12:52
Helo,
perhaps you try the following:
"weather - weatherforecast - statistic dates" and there press the button "reset" at last rain.
Then go back and choose "View - year"
Afterwards it should bei all right.
Verfasst: 11 Mär 2007 13:57
von Ryant
Thanks Werner, I tried that but it keeps returning to the last minute.
Verfasst: 11 Mär 2007 14:37
Hello,
I've no idea for the moment. Perhaps Werner can help you. But you should correct your link, there is a dot at the end, so it doesn't work.
correct
Verfasst: 11 Mär 2007 14:50
Hello,
one more idea to try:
- do the same as I have already told you and then:
- "internet - update Graphics/Tables" and there set a hook at "Dryness Icedays Time" and "year file"
Then choose the whole year for actualisation. I hope, it will work.
Verfasst: 11 Mär 2007 15:24
von Ryant
Hello again,
I've tried what you suggested, but it's still the same. It's been there on all versions of WsWin but can't get rid of it.
Thanks anyway.
Ryan.
Verfasst: 11 Mär 2007 15:52
@Ryan,
it think you set at
Weather station, Special sensors, #3
and here at Time sensor a wrong sensor or a wrong value.
Or disable there "Pricipitation strength".
Verfasst: 11 Mär 2007 16:19
von Ryant
Thanks Werner, I had "Pricipitation strength" ticked. Removing that has now corrected everything.
Cheers for your help.
Ryan
