Reset Clear all graphs etc in PC wetterstation
Verfasst: 25 Mär 2007 00:03
von dennisjames1
Hello i would like to clear all graphs and info from the software and start again i have been having some issues with my Honeywell station, so i would like to clear all that incorrect data from WsWin, i did uninstall the software and deleted the WsWin folder, but the data must located elsewhere in another folder as when i reinstalled WsWin again it was still there, how do i removed this data ,oh yes i also know how to reset the Honeywell station and i did that as well....cheers Dennis
Verfasst: 25 Mär 2007 09:46
Hello Dennis,
That's not possible, the files are only in the wswin-folder.
delete all the month-files like ws_mm_jj.dat (or wd_mm_jj.dat) and you will have no longer any old data
And when you want to start completelely new, also delete the file wswin.cfg
You need not deinstall WSWIN
Verfasst: 25 Mär 2007 11:27
von dennisjames1
Hey Thank-you will give it ago cheers!
