Wind Direction Smoothing
Posted: 08 Oct 2026 16:37
Translated from French by Google (original French at the bottom of the page)
I hope I'm in the right forum?
On weather stations with low wind direction resolution (22.5° on my Lacrosse station), the representation of this direction on WSwin32 graphs is very difficult to read and very "polluting."
For example:
Using the "Smoothing" function greatly improves this readability:
same graph with wind direction Smoothed:
The problem is that a smoothed northerly wind appears as a southerly wind:
Unsmoothed northerly wind:
Smoothed northerly wind: completely distorted and unreadable!
I saw on a weather website (I don't remember which one) that it's mathematically (and therefore computationally) possible to correct this flaw so that when smoothing (averaging) a northerly wind on a linear graph, it doesn't pass through the south.
Would it be possible to offer this correction as an option in Wswin32?
That would be a great improvement!
Note:
I described this problem in the Infoclimat forum in 2020 in these two posts:
https://forums.infoclimat.fr/f/topic/37 ... t=3290609
and
https://forums.infoclimat.fr/f/topic/37 ... nt=3290687
Original en français:
8 octobre 2026
Lissage direction du vent
Traduit du français par Google
J’espère que je suis dans le bon forum ?
Sur les stations météo dont la résolution de la direction du vent est faible (22.5° sur ma Lacrosse), la représentation de cette direction sur les graphiques de WSwin32 est très mal lisible et très "polluante"
par exemple:
https://forums.infoclimat.fr/uploads/mo ... 321051.gif
L'utilisation de la fonction "Lissage" améliore beaucoup cette lisibilité:
même graphique avec direction du vent lissé:
https://forums.infoclimat.fr/uploads/mo ... b990bc.gif
Le problème c'est qu'un vent du Nord lissé se retrouve avec un vent de Sud affiché:
vent de Nord non lissé:
https://forums.infoclimat.fr/uploads/mo ... b33e1f.gif
vent de Nord lissé: complètement faussé et illisible !
https://forums.infoclimat.fr/uploads/mo ... 7da4af.gif
j'avais vu sur un site météo (je ne sais plus lequel) qu'il est possible mathématiquement (et donc informatiquement) de corriger ce défaut pour que lors d'un lissage (moyenne) d'un vent de Nord sur un graphique linéaire, il ne passe pas par le Sud.
Serait-il possible de proposer cette correction, en option, dans Wswin32 ?
Ce serait une grande amélioration !
Remarque:
J'avais décrit ce problème dans le forum Infoclimat en 2020 dans ces deux posts
https://forums.infoclimat.fr/f/topic/37 ... nt=3290609
et
For example:
Note:
and
8 octobre 2026
par exemple:
Remarque:
et
