Hello,
your east-coordinate is not allright. You have to use no negative value.
Type in 174 47 48 and not
-174 47 48
But in the south coordinat you have to take a negative value, that means
-41
Hello,
I fear I can't help you.
There's no problem. When I enter -41 12 59 it is shown as -41.216389
and when I enter 147 47 48 it is shown as 147.796667
What version of WSWIN do you use?
weneu hat geschrieben:Hello,
So do I. No problem here. The coordinates are right. I had to switch the timezone of my windows and then to restart WsWin to get the correct sunrise/sunset time. But then it worked perfectly. All with the latest version of WsWin.
With purchased version it is better, but sunrise and sunset times are wrong by 1 hour exactly. Does wswin take into account day light savings ? I have tested changing system clock and system daylight saving settings but still the same.
