When I change some of the properties for Internet, for example “HTML Folder” and than close the program, start again. All the changes are gone and back to default.
Do you have write-rights on the wswin-folder and the files incuded?
or
You habe copied the WsWin-Files from a backup on cdrom?
Then you must change the file-attributes from write-protect.
Hi jekno,
Thanks, but write-rights are not the problem.
The funny thing is that if I change the field “Wap Folder” (internet settings) and restart the program the changes are remembered but if I do the same for “HTML Folder” than the changes are lost when I restart the program.
