WsWin Freezes
Ryant
WsWin Freezes
Beitrag von Ryant »
Good morning all.
I've had a couple of problems of WsWin freezing. Here's the error reports:
17/02/2007 08:15:51.171 V2.93.8 1 50 0 Error painting diagram - DebugNr:8 ID:0 YCnt:7 MCnt:12
19/02/2007 07:48:53.296 V2.93.8 1 50 0 Error painting diagram - DebugNr:8 ID:0 YCnt:7 MCnt:13
I'm using v2.93.8 and have the irox weatherstation, any idea's how to avoid WsWin freezing?
Thanks.
Danksagung erhalten: 141 mal
@Ryan,
here is something wrong with/at
showing rain "as Process".
Do you have a Dual Core CPU?
Ryant
Beitrag von Ryant »
No its not Werner.
@Ryan,
do you guarantee, that the iroxdata.exe didn't remain in the memory
or is started?
Ryant
Beitrag von Ryant »
I'm fairly sure its not. If i've run WD, I normally make sure iroxdata.exe had been shut down from the task manager.
This morning I went to choose the statistics from the menu and WsWin froze and made windows unstable, so I had to reboot. No error was recorded. This only seems to happen after midnight.
Would it help if I re-installed wswin?
@Ryan,
normally not.
But you can try:
rename the wswin.cfg (before wswin started)
you need to set here all settings again.
Ryant
Beitrag von Ryant »
Thanks Werner, i'll give it a try and see if its ok in the morning. For some reason this seems to happen overnight...
