UV sensor compatibility Irox / Cresta / Mebus
Stefan10
Beitrag von Stefan10 »
Good afternoon,
Is it posible to use an UV sensor from the Cresta WXR-815 with the Irox Pro USB?
And if that is so, can I use the (433mhz) UV sensor from any Cresta weatherstation for the Irox?
Stefan
@Stefan,
YES!
You can mix the sensors from Honeywell, Mebus, Irox, Cresta, NEXUS ...
If you have one station from Cresta and one from Irox -> then you can store a sensor set (wind, rain, uv) as a backup.
And using the temp/hum sensor from the second station as sensor 2...5.
Stefan10
Thank you for the quick answer Werner!
And can I also use the sensor from, for example, the CrestaWXR 850 UV (http://www.kijkshop.nl/product/14828/12 ... wxr-850-uv) for my Irox pro?
Greetings,
Stefan
@Stefan,
I'm here not sure - because this seems to be a other design (like Irox, Mebus ...)
Stefan10
Well I tried it.
I bought the CrestaWXR 850 UV yesterday to try. The UV sensor and the temp/hum. sensor are working fine on my Irox Pro and vice versa.
By the way, the CrestaWXR 850 UV is the same as the Irox HBVR761 UV-X.
Stefan
jupppo
Beitrag von jupppo »
Would an Irox UV Sensor also work on a nexus? I know that the nexus has cannot display UV, but perhapt the identical hardware stores the measurements and they can be read by WSWIN then?
