HELP: WsWin import data of single sensor
dino77
Beitrag von dino77 »
Blank!
I have the Lacrosse ws2500 and PC-interface ws7000-13 (ws2000-PC). I download the data with the software originates supplied them with the station, then converts them in WsWin (v 2.93.10 fullversion).
My problem is this: the ws2000-PC does not receive the data from the luxmeter, therefore it is possible to import the data of the sensor luxmeter from the software ws2500, and instead all the other data from software ws2000-PC?
Practically, I would want to make a “mix” between data ws2000-PC and the data of the sensor of the brightness.
How are imported the data of a single sensor? Thanks hello :)
Hello,
it should be possible to use the file ws_merge.csv
You store the data of the luxmeter in a file called ws_merge.csv and whenever new data arrive, WSWIN will import the file ws_merge.csv.
Have a look at "weatherstation - Interface type" and there at "file watching"
There you can set a hook at "ws_merge.csv -->active"
The file must have the structure of the normal export-file of WSWIN
