Reset Clear all graphs etc in PC wetterstation
dennisjames1
Hello i would like to clear all graphs and info from the software and start again i have been having some issues with my Honeywell station, so i would like to clear all that incorrect data from WsWin, i did uninstall the software and deleted the WsWin folder, but the data must located elsewhere in another folder as when i reinstalled WsWin again it was still there, how do i removed this data ,oh yes i also know how to reset the Honeywell station and i did that as well....cheers Dennis
Hello Dennis,
delete all the month-files like ws_mm_jj.dat (or wd_mm_jj.dat) and you will have no longer any old data
And when you want to start completelely new, also delete the file wswin.cfg
You need not deinstall WSWIN
That's not possible, the files are only in the wswin-folder.but the data must located elsewhere in another folder
