VP2 Firmware 3.12
Macs
VP2 Firmware 3.12
Beitrag von Macs »
Hallo Wetterfreunde!
Es gibt für die VP2 bereits die Fimware Version 3.12
Hier die Links:
cabled: http://www.davisnet.com/support/weather ... wareID=230
wireless: http://www.davisnet.com/support/weather ... wareID=223
Version History
Firmware version 3.12
- Fixed a bug in 3.00 that did not allow the ET alarm to be cleared.
- Eliminates occasional WeatherLink communication issue when console is busy receiving a radio packet.
Firmware version 3.00
- Console times out of the "Receiving From" setup screen after 15 minutes using batteries and 30 minutes using AC power.
- Previous versions of firmware allowed a negative ET, now it will clip hourly ET values at 0.
- Added leading zero to temp readings between -1.0 and 1.0.
- Improved temp and hum index calculations.
- Low humidity readings now clipped at 1% and will not show 0%.
Firmware version 1.90
- CWOP uploads will now contain 2 min average wind speed, 10 min wind gust and direction of gust, last 15 minutes of rain, last 1 hour of rain and Altimeter. Must also have WeatherLink software v5.9.0 or later to use this feature.
- Fixed a bug that caused the barometer value to have a large error after updating to firmware version 1.82
Before You Install
IMPORTANT! This firmware is only for Vantage Pro2 Cabled Consoles manufactured April 2006 or later (#6312C, #6312COV, #6312CUK, #6312CEU). The Inside Temp, Inside Hum, and Barometer readings will not appear if 3.12 firmware is installed on consoles manufactured before April 2006.
Vorsichtige Anfrage an Werner: wird es diese irgendwann auch wieder auf Deutsch geben? :roll:
Danke!
Lg Macs
VantagePro2 - WsWin 2.97.5
@Macs
DAVIS hat die V3er Firmwaren "verschlüsselt" - d.h. sie werden erst beim Übertragen auf die Konsole entschlüsselt.
Hab bisher keine Möglichkeit gefunden, die Verschlüsselung aufzuheben und dann die Firmware "patchen" zu können.
Macs
Beitrag von Macs »
Alles klar, Danke für die Info und deine Bemühungen, Werner!
Lg Macs
derwettermann
Beitrag von derwettermann »
einfache Frage lohnt der Aufwand ?
Never Touch a running System :.)
Grüße Roland
@Roland,
kann ich nicht wirklich beantworten.
Was ich jedenfalls festgestellt habe, bei Wind unter 10 km/h
zeigt V3.x andere Werte wie die V1.9.
... und Vorsicht mit der Firmware 3.x!
bei Geräten gebaut vor 2006 werden keine "Innendaten = Temp, Feuchte, Luftdruck" mehr angezeigt.
Solche Geräte sind im Status Console bei den "Luftdruck CAL-Daten" erkennbar, speziell am Wert "Offset" - der ist bei neueren Geräten viel niedriger.
derwettermann
Was ich jedenfalls festgestellt habe, bei Wind unter 10 km/h zeigt V3.x andere Werte wie die V1.9
Meine Frage wie groß ist der Unterschied ( weniger / mehr )
Danke für die Info im voraus Gruß Roland
@Roland,
muss mich korrigieren - es muss über 10 km/h heißen.
Hab momentan nur Wind um 10km/h.
bei 11 km/h (V1.9-Vantage) wird bei V3-Vantage 12 km/h angezeigt.
derwettermann
mir ist bei V3.12 letzte Woche folgendes aufgefallen.
Bei den Stationen mit der ID 2 3 und 4 waren die Batterien schwach
Stand im Display der Console wechselweise
Low Batterie on Station 2 "Pause 1 Sec" Low Batterie on Station 4 "Pause" Low Batterie on Station 2 usw....
Ist mir bei V1.9 so noch nie aufgefallen.
Warum die ID 3 nicht Angezeigt wurde ?
Vielleicht meinte das System ja von 2 bis 4 :wink:
Grüße Der Wettermann
Technik:
Vantage Pro 2 Aktive Plus ( Console / als Backup Envoy ) + Blitzortung
