temp sensors won't work
Hi Walter,
if the temp sensor (or other) are not recognized -> you should deactived the "Check read in weather data to plausiblity" (under File, Options).
This is the general option.
Or for each sensor in "Properties ..." (under File) and there deselect "Plausibility-correction".
