Rain value in ws_newdata.csv
jackT
hello,
I am using the automatic export of data (in ws_newdata.csv) in order to import data to an SQL server database.
This data export was working good since several month, but I just observed today that the rain value written in ws_newdata.csv is always 0, even if a rain value is captured by wswin. Is it a bug appeared in the last version? (we had no rain here since January 1st and it was working with previous versions)
For instance today at 10:00, the rain was 0.2 mm. Rain values in wswin is OK, rain written in aktuell.txt is 0,2 mm , but rain written in ws_newdata.csv is 0 !!
regards
JackT (wswin+ Vantage Pro2)
regards
jackT
Hello Werner,weneu hat geschrieben: Perhaps you must control the rain sensor.
"Weather station" --> available sensor --> hook at "sensor rain"
"View - show selected sensors" -->rain sensor enabled?
Thanks for your reply. The sensor is selected and enabled, and the rain data are correctly display on the wswin screen as well as in the recorded data and statistics
The only problem is that now the rain data written to the ws_newdata.csv are always zero...and it was not the case before!
Regards
Jack
http://meteo.terrettaz.net
jackT
As an example, here was the content of my ws_newdata.csv a few minutes ago :
and here is the corresponding lines extracted from the file aktuell.txt :
The rain is correct in aktuell.txt (0.600 - 0.400 - 0.400), but is always 0.000 in ws_newdata.csv
By writing this post, I observed also that the wind data are not the same between the 2 files!!!
Why are these values different? Is it because I am using my Vantage Pro 2 in near real time mode?
Regards
JackT
Date,Horaire,Temp. I.,Temp. E.,Temp. E. min,Temp. E. max,Hum. I.,Hum. E.,P.atmo.,Pluie,Vent,Direction,P. de rosÈe,Temp au vent,Rafales,RÈception
,,?C,?C,?C,?C,%,%,hPa,l/m?,km/h,?,?C,?C,km/h,%
17.01.2006,18:20,22.3,5.8,5.8,5.8,41,81,1010.9,0.000,9.7,180,2.8,3.2,30.6,75.2
17.01.2006,18:30,22.3,5.7,5.7,5.7,42,81,1010.9,0.000,14.5,210,2.7,0.2,24.1,75.7
17.01.2006,18:40,22.3,5.7,5.7,5.7,41,80,1010.9,0.000,4.8,196,2.5,5.7,33.8,73.0Code: Alles auswählen
17.01.2006;18:20;22.3;5.8;5.8;6.0;41;81;1010.9;0.600;8.5;180;2.8;4.0;30.6;75.21;8;4;184
17.01.2006;18:30;22.3;5.7;5.7;5.8;42;81;1010.9;0.400;9.1;210;2.7;3.5;24.1;75.73;14;4;184
17.01.2006;18:40;22.3;5.7;5.7;5.7;41;80;1010.9;0.400;11.6;196;2.5;1.8;33.8;72.96;10;4;184
Regards
JackT
jackT
