Bugs in wswin32 2.93.5 with Davis VP2
Arcibald
Hi,
Found bug in wswin 2.93.5, with it I use of 2 sensors temperature the Tmax is always equal
Regards
Regards
Arcibald
Excuse but for me there is a bug in the software
Here there are the values read from the sensors and are different !!
http://www.meteopiateda.it/Piateda/PC/20061016.htm
Best regards
Best regards
Arcibald
Arcibald
Hello Werner
In quarter column of http://www.meteopiateda.it/Piateda/PC/20061016.htm ( T.Est 2m.) I never do not see 19.3°C unless in “massima” line.
It is mistaken because the tmax 2m of the 16/10/2006 it is 18.9°C.
The timetable of the "Max-Ora" (2m sensor) is mistaken because the Tmax 2m it has been recorded to the 13,32.
Martin
Martin
Arcibald
It does not appeal to not even me this solution, but in order not to leave in shadow the solar sensors, I have had to install the iss on the house roof and to put an extra sensor in garden.Werner hat geschrieben:@Martin,
I didn't assume that someone uses for
main outdoor temperature a second (extra) temperature sensor,
which isn't so accurately and has a only resolution of ~0.5 °C
Thank you.Werner hat geschrieben:@Martin,
I will correct that.
Martin
