Hello!
I have only one question. I need to generate simple TXT file in this format:
DD.MM.YYYY|HH:MM|TT.T|VV|TTTT.T|RR.R|SSS|DD.D|
12.11.2006|14:54|14.2|58|1027.4|1.8|257|0.5|
Date|time|temperature|humidity|presure|wind speed|wind direction|precipitation per 1 hour|
Please is it possible to generate file in this format every 15 minutes. ?
Thank you for your help!
TXT file generation
Hello,
either you take the "aktuell.txt" as it is, example here
or you use a user-defined template with the wswin-variables to get exactly, what you want.24.02.2007;00:00;20,7;4,2;4,2;4,3;44;90;1009,9;0,000;0,0;96;0;0,000;0,0;0;2,7;4,2;0,0;100,00;0;5;45
24.02.2007;00:05;20,7;4,1;4,1;4,2;44;90;1009,9;0,000;0,0;0;0;0,000;0,0;0;2,6;4,1;0,0;100,00;0;0;45
flax
Hello,
You create a file containing the following:
<!-- %customfile=aktuellwert.txt% -->
%unit_off%%ws_date%;%ws_time%;%curval[0]%;%curval[-1]%;%curval[33]%;%curval[35]%;%curval[36]%;%rain1h%
This file you call for example "daten.txt" and store it in the programm-folder.
Then you open the file "wap.txt" (it's in th e programm-folder) and in the second line of this file you insert
<!-- %openfile=daten.txt% -->
and store the file again.
Then the following will happen:
Whenever wswin gets data from your station, it will look for the file "daten.txt" and open it.
Then it will create the file "aktuellwert.txt"
And in this file you will find the actual data.
Be sure that you have set a hook in WSWIN at "Internet - adjustments" and there at "update customized html files in recording mode"
